Cheap and simple upgrade for OEM Speakers
Old Jan 9, 2006 | 01:02 AM
Sumaccordguy1994's Avatar
Found THESE and decided to give them a try. They are a perfect fit for the rear 6x9 speakers and actually have decent sound to them. They fit snugly into the speakers frames and the OEM bolts can still be used. A couple "clips" on the grilles have to be removed, but the grills still hold just fine.
Also got a pair of THESE, took them off the brackets and mounted them in place of the front tweeters, they mount right to the OEM bracket and the wires are easy to splice. They come on "RH" or "LH" brackets, I ordered one of each... but realized that one tweeter is wired backwards. If you go with both "LH" tweeters, the wire colors will match the OEM wires in the car. These are the same tweeters as whats mounted in the 6x9 brackets above.
Just wanted to share this find with people looking to get a little better sound without spending much money at all.
This will work with or without the bose system. My test was done on a car with the bose stereo and the results were quite impressive, really brought out alot of detail in the stereo.
Old Jan 9, 2006 | 10:13 PM
NauTiC*'s Avatar
Not sure what I'm looking at. What is it and what dose it do ?
Old Jan 9, 2006 | 10:27 PM
ghost_masterCL's Avatar
it's tweeter upgrades for hte sound system.
tweeters are very small speakers that are basically the opposite of sub's. they only do higher pitched frequencies, and since they are made just for that they give a clearere sound for those frequencies.
personally tweeters hurt my ears, so I won't be getting these.
Old Jan 9, 2006 | 10:31 PM
rage007's Avatar
99 2.3CL, 5sp, Iced Teal
Adds some high range to the mediocre stock 6x9s:
Frequency range: 6,000-20,000 Hz
Total bolt on install, sounds worth $4. Can't even get a damned beer around DC for that price. Although I'm sure its the cue for someone to start spitting vitriol about the stock head unit...
Old Jan 9, 2006 | 10:54 PM
tman89544's Avatar
Can you post pics of what this looks like? Ive been interested in adding an additional Bose speaker on my door panel but dont want it to look out of place.
Old Jan 10, 2006 | 12:40 AM
Smalls's Avatar
Insert Sarcasm Here
^leahood, thats funny
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
handsom-hustla
Nov 13, 2015 05:04 PM
sockr1
Oct 1, 2015 01:31 AM
iRaw
ILX
Sep 5, 2015 12:10 AM
MyKids&Cars
Sep 1, 2015 12:53 PM
