Changing Tranny oil and need help...
CL- SMOOTH
I need to know if there is one nut that needs to be removed in order for me to drain the tranny fluid on a 97 3.0 CL and exactly where it's located ?? Thanks....
I just did that the other day. The drain plug is on the very bottom of the tranny and lays horizontally (not bolted from below, but sideways). It is different color (bronze?) and if it is the same as on my '99 3.0 you can use a 1/4 inch socket wrench extension to remove it.
CL- SMOOTH
just make sure you use honda atf ...if ya didn't know anyway and it takes 3.1 quarts at a change out (according to factory manual) for complete flush (if ya were overhaulin tranny) 7.6 quarts
Gimmie my points Biatch!
Originally Posted by Chinisimo
is it better to have it drain from the bottom so in any lil metal shavings will come out along w/ the fluid?
AWD Torque Monster
Originally Posted by fusionnv
Hmm normal wear would be subspended in the oil. If the metal wear would be heavier than the oil and would cause a problem, you probably have a bigger issue with ur tranny.
the drain plug has a magnet that attracts all the small metal pieces. i clean that off each time. kinda looks like graphite.
Thanks...How many Qts does it take to fill up ?? I was told 4...True ??
I'll do a 2nd drain & fill tonight...
to get the most out of ur tranny move the shifter back and fourth between gears while the drain plug is out. (this opens all the hydraulic valves ull get about 1/2 qt more out.) do not start the car.
i really suggest a tranny cooler
From post I sounds like a good idea. I going to do this next on my list.
Edit: before u mukerfukrs say where can i find that:
http://www.acura-cl.com/forums/showt...threadid=73356
this is what i was talking about...
Also, before you do that, make sure to take out the top bolt. Would suck if you drained the fluid and couldn't take out the bolt...then you'd have to use the dipstick.
do u need to use honda ATF?
crap!! i just bought 5 quarts of dexron III ...freakin...
theres a bolt on top heres a pic.
http://pg.photos.yahoo.com/ph/wilp99...&.dnm=5f39.jpg
it is the one circled in red.
Flamenco Blk 3.0CL PREM
this is the first automatic i owned ,, so how often should i change the tranny oil ??? .. i've had it for two years and i first changed it about 2 3 months ago !!
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
