CEL on 2.3 - code 76 - help
Old Jun 17, 2006 | 04:27 PM
ingsoc747's Avatar
Question CEL on 2.3 - code 76 - help
Well my CEL came on again and this time I actually decided to see what it was bithcing about... so I do the ole' paper clip test and the code comes out 76...
I can't find a code listing for the 2.3 anywhere on here, and a code 76 on a 3.0 is "cylinder 6 misfire", which obviously doesn't help me.. does anyone have any input on this issue?? thanks
Old Jun 17, 2006 | 06:32 PM
TexasHonda's Avatar
Are you sure of the code? Seven long flashes plus six short flashes would be a 76. If seven short, 4-5 sec pause, 6 short, then two codes, 7 and 6 are presented.
I checked 97 Acura 2.2CL and Mitchell on Demand did not have a code 76.
good luck
Old Jun 18, 2006 | 11:14 AM
ingsoc747's Avatar
there was definitely no pause, but perhaps i miscounted the flashes... ill try it again and get back to you, thanks
Old Jun 18, 2006 | 03:39 PM
ingsoc747's Avatar
ok... i checked again and its really code 67 - guess i was temporarily dyslexic when i first pulled the code!!!
EDIT: the FAQ says
67.............P0420.............................. Catalyst system efficiency below threshold
is this the same for 2.3 and 3.0?
Old Jun 19, 2006 | 05:54 AM
TexasHonda's Avatar
This is a tough one to fix. It could be simple such as an exhaust system leak allowing air into the exhaust, or could require catalytic converter replacement to fix. If you're not DiY, then professional help is indicated to sort out the problem.
Basically, the rear O2 sensor is indicating the catalytic converter is not performing up to requirements. The sensor sees too large swings in O2 content and after so many counts of O2 swings it sets the P0420 flag.
Note, P0420 does not cause any drivability problems, but you can't pass a state emissions inspection w/ the code set.
good luck
Old Jun 19, 2006 | 09:03 PM
ingsoc747's Avatar
good luck
My cat was just replaced 3000 miles ago. It might be an exhaust system leak since I've been having a strange resonance type noise at 1800 rpm that i've been unable to pinpoint (seems to come from under the car around the front seats). Perhaps its the downpipe? (my intermediate was replaced this winter as well)
Old Jun 19, 2006 | 09:08 PM
TexasHonda's Avatar
An air leak into intake manifold, flex pipe, connection, or other component will cause P0420 to occur. Exhaust manifolds are notorious to crack. Remove heat shields and look closely.
good luck
Old Jun 19, 2006 | 09:16 PM
ingsoc747's Avatar
good luck
Can this also cause a lack of engine power?
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
hrothgar02
Sep 28, 2015 11:08 AM
