Can i splice into remote wire going into bose amp
whats up everyone, i need somewhere to run my remote blue wire. i was wondering if i could splice it into the blue one going into bose amp. i couldntfind anywehre to hook it up behind my new deck and i need somewhere to put it so my subs will works thaks
-S namyaC-
I don't think it's the blue wire on the Bose amp, but there is an wire that you should be able to use. I have the pinouts at home, I'll post up the right wire later. Also, what exact model deck and amp do you have?
-S namyaC-
Ok - at the back of the radio OR at the Bose amp in the trunk - the YELLOW with WHITE stripe is the remote turn on (IE on w/ ignition in Acc or Run). Make sure you get the right one, as there are some others that may look similar (IE solid yellow, etc).
But before you do anything, give us the model #s of your rasdio and amp.
InFaMouSLink
10-30-2015 09:43 AM
SUPRMN84
10-07-2015 09:46 PM
