Can an Auto Stall?
Old Jun 27, 2001 | 07:35 PM
TwoTwoVtech's Avatar
Can an Auto Stall?
I know this sounds wierd, but I think my automatic CL stalled. I was backing out of my garage to go to school this morning and stopped to put it in D, I had my music on pretty loud, and out of nowhere my engine just shutoff. The stereo was still on but to motor was off, this is the second time this happend since i bought my car 4 months ago. If this happed to anyone, any help or advice would be great. Thanks
Old Jun 27, 2001 | 09:30 PM
3PointZero's Avatar
Never had this happen on my CL, but it happened to my old Legend. Its was cause the fuel injectors were clogged. It might not be your case, but its something to look into.
1998 Black 3.0 CL
AEM CAI
Wings West Front Lip
Old Jun 27, 2001 | 10:06 PM
RidinLow's Avatar
Scooby Guru
If you leave it in D & let it roll backwards, it can stall, but otherwise it shouldn't. How many miles are on your car? Perhaps you have a clogged air filter or bad plugs?
'02 WRX Wagon (OZ Superleggeras, removed intake silencer, K&N panel filter, Dawes Devices Manual Boost Controller, etc)
'97 2.2CL (removed intake silencer, K&N panel filter, interior neon lights & other ricey mods)
Old Jun 28, 2001 | 02:27 AM
VXCL's Avatar
AWD Torque Monster
i had that happen once. my drive way is a hill so i gave it gas, rolled down a little, gave it gas, rolled down a little, i was just fuckin around and my car stalled. it never did since though. also if u hold the brake and rev to live 2000+ rpms i think the car will stall also.
1997 Black Acura 2.2 CL
See It Here
Old Jun 28, 2001 | 02:33 AM
I have 56,000 miles on it and everything looks fine but I'm gonna get it checked out, thanks
Old Jun 28, 2001 | 02:34 AM
RidinLow's Avatar
Scooby Guru
<font face="Verdana, Arial" size="2">also if u hold the brake and rev to live 2000+ rpms i think the car will stall also.</font>
It shouldn't stall when you brake torque...
Anyway, you have quite a few miles. Pop open the filterbox & check on the status of the air filter. A dirty & clogged filter is usually the cause of stumbling & stalling at idle.
If it's clean, pull the plugs & check those too. A new set of NGK copper plugs should run you about 10 bucks & make the engine much happier.
[This message has been edited by RidinLow (edited 06-28-2001).]
Old Jun 28, 2001 | 02:54 AM
VXCL's Avatar
AWD Torque Monster
i prob just misundrstood what i read. what does it mean then stall speed? rpms wise? is that for the tranny??
See It Here
Old Jun 28, 2001 | 02:05 PM
T_CLS's Avatar
I would recommend you use a good fuel injector cleaner the next time you fill up. It may also be time to replace your fuel filter. I had this problem on my Eclipse before and replacing the fuel filter did the job.
Old Jun 28, 2001 | 02:12 PM
RidinLow's Avatar
Scooby Guru
VX, I found this off some site:
To test the stall speed on your current torque converter:
With the engine running, the emergency brake fully applied and the brake pedal held firmly with your left foot put the selector in drive and depress the accelerator fully to the floor with your right foot for four seconds. Your stall speed will be the maximum RPM shown on the tach.
DO NOT HOLD ACCELERATOR TO MAXIMUM RPM FOR MORE THAN 4 SECONDS AND ONLY PERFORM TEST WITH A FULLY WARMED UP VEHICLE and A VEHICLE WHO'S EMERGENCY AND NORMAL BRAKING SYSTEMS ARE IN FACT WORKING PROPERLY.
Old Jul 21, 2008 | 05:03 PM
purple3.0haze's Avatar
yeah this happened to me when i shifted from reverse into drive while i was still moving backwards
Old Jul 21, 2008 | 05:23 PM
GhettoNinja06's Avatar
Skuuuurrrrrt!
Holy jebus man! That is like, half of my miles. Pics! I bet it looks like new.
edit: then again, this was 7 years ago...
Old Jul 21, 2008 | 05:25 PM
ckrowland's Avatar
you do realize this is a 7 year old thread!
Old Jul 21, 2008 | 06:19 PM
Eband27's Avatar
hahah, my car probably had like 15k miles 7 years ago! it now has arround 55k miles :-)
Old Jul 21, 2008 | 07:58 PM
South Jersey CL's Avatar
mine just turned 60,000 miles the other day.
i love these 7-year old threads. they seem so ancient.
Old Jul 22, 2008 | 01:16 AM
artbran's Avatar
666 Speed
kinda makes you think about what you were doing 7 years ago when this was written.
Old Jul 22, 2008 | 01:29 AM
Skuuuurrrrrt!
Haha! I was collecting Hot Wheels! lmao!
Old Jul 22, 2008 | 08:53 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Driving a nicer, newer car than the CL
Old Jul 22, 2008 | 01:57 PM
thats what i was doing! that and watching spongebob squarepants.
Old Jul 22, 2008 | 02:15 PM
Skuuuurrrrrt!
Haha! Actually I was in Slime Time Live and I don't even think spongebob came out 7 years ago. This was wayyyy back when cartoons were actually decent..
Old Jul 22, 2008 | 02:43 PM
(Mid-Atlantic)
Old Jul 23, 2008 | 10:41 PM
bmanc42's Avatar
8th Gear
i got 65k on my 99 bought it this year with 52k
Old Jul 23, 2008 | 10:46 PM
Skuuuurrrrrt!
I just stalled my auto!!!
Yeah, I engaged the handbrake and right when I went to put the gear in park, my phone rings, I answer it, I talk for a little while, hang up, noticed the car was still on, turned the key WHILE IT WAS IN D4, and it shook real hard then shut off.. I thought it wasn't supposed to let you do that? I guess not.
Old Jul 24, 2008 | 12:53 AM
G22_Powered_YA1's Avatar
happened to me once, I was making a 3-point turn dropped it into D real quick and the engine stalled out. . . problem is my viper alarm had a starter kill to shut off the starter when the engine turned off and wouldnt arm the starter again till I hit the disarm button. . . VERY hectic moment
just that once, and nerver again afterwards
Old Jul 24, 2008 | 08:57 AM
SwervinCL's Avatar
Nom Nom Nom Nom
Used to happen every once in a while in my accord. I would be sitting at a light and it would just die. Other than that, it ran perfect..
On a side note, maybe I just have bad luck with Hondas. Can't wait to get rid of mine.
Old Jul 24, 2008 | 09:03 AM
SLIME TIME LIVE!!
Old Jul 24, 2008 | 09:10 AM
1slo23's Avatar
Runs on Dunkin
my old ranger stalled sometimes and it was and auto, so its not unheard of
Old Jul 24, 2008 | 11:07 AM
swiftt5389's Avatar
SLIME TIME LIVE!!
Dude Rocket Power and the Rugrats were amazing.
and oh yea
Kenan and Kel! lmao
Old Jul 24, 2008 | 12:47 PM
(Mid-Atlantic)
who loves orange soda? kellllllllllllll doessssssssssss
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
malvothegreat
Sep 29, 2015 12:38 AM
jmaxima03
Sep 27, 2015 10:22 AM
prbori
Sep 27, 2015 01:37 AM
