Camber kit questions
Old Apr 10, 2003 | 08:53 PM
Epoc's Avatar
Stylin CL
Well, im gonna try this again after sending the first kit back because they sent me the wrong one, i just recived the new one. Along with the kit im having illuminas and 2.5f/2.25b springs put on. Will i have a problem with the clearance in the front? The instructions that came with the kit say that if the adjustment is more than 2 degrees modification of the fender wall or arm will be necissary. What the hell does that mean?
Old Apr 10, 2003 | 10:26 PM
indopinoy's Avatar
very punny....
you might have clearance problems.
ive heard of people with camber kits and no problems, but personally....ive had a hell of a bad time with mine.
in my case, the inner fender would sit on the control arm with the camber kit in. i was told i would need to shave the innerfender to make it fit, and that was not a guaranteed solution
Old Apr 11, 2003 | 03:01 PM
Epoc's Avatar
Stylin CL
can the camber kit still be installed and drove on for a short time until i get that fixed?
Also you had cleance problems with yours, did you have to shave the fender wall or did you wait to install the kit?
Old Apr 12, 2003 | 07:35 AM
Epoc's Avatar
Stylin CL
Any1? Will i have to modify the inner fender wall when i install the camber kit?
Old Apr 12, 2003 | 12:42 PM
wingman's Avatar
Old Man
Yes, you most likely will. It is the camber kit that causes the clearance problem not the springs. Depending on the kit (I never looked at the sprint kits) if the upper arm pivots change (moved out) you will have a problem.
Old Apr 12, 2003 | 07:25 PM
Epoc's Avatar
Stylin CL
well the front uses the anchor bolts to change the camber, really dont know what that will entail as far as the parts moving. Is cutting the inner fender wall or modifing the inner fender wall an easy job?
Old Apr 13, 2003 | 01:01 PM
Acura3.0CL's Avatar
DamnThisHobby'sExpensive!
Hey, i might buy some H&R springs...(used) the front drop is 1.7" and the back is 1.5"....does ANYONE know ANYTHING about H&R springs?? good or bad??
IF i drop the front 1.7 and the back 1.5...WILL I NEED A CAMBER KIT?? Can i use the stock shocks??????
BoricuaTL
Apr 8, 2016 01:08 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
datadr
Sep 12, 2015 09:12 PM
nuldabz
Sep 3, 2015 05:49 PM
datadr
Sep 2, 2015 06:46 PM
