Brake rotor question 98 2.3 CL
I'm doing the CL brake conversion on my accord so that it will have the rotor over hub design and one problem I have run into is that when I ordered the hubs I also got the set screws as well and I ordered a set of Powerslot rotors and when I put the rotors on the hubs the set screw holes don't line up. No matter which way I put the rotors the screw holes never line up, I called powerslot and they told me that it was acura that changed the postion of the set screws on the hubs and that on some of the hubs the holes will line up and others they will not. They also told me that honda/acura only uses those screws to hold the rotors on during the production of the cars and that they tested them with out the set screws and have had no problems.
Has anyone else run across the set screws not lining up with aftermarket rotrs.
Sorry about the long post
Accordhybrid
Accordhybrid
asahrts
09-04-2015 05:55 PM
