Brake lights out. Short?
Old Aug 19, 2004 | 01:23 PM
archie2004's Avatar
Have a 99 2.3CL. My brake lamp light went on on my dash, so I went back a checked it out. Sure enough both middle brake lamp and driver's-side brake light were out. Checked bulbs - middle brake lamp bulb was indeed burned out, while driver's brake bulb was fine. Replaced middle brake lamp bulb, and still nothing. Took bulb back out to check if it had burned out, it's fine. I check the fuse, it's fine, too. Since both bulbs are not working, I think this narrows it down to a short. Does this sound right? Any ideas on how hard this will be to fix? Any ideas where I can find a schematic of the wiring of the car? Any help would be appreciated, I have to pass safety inspection in next two weeks. Thnx.
Old Aug 19, 2004 | 02:07 PM
fusionnv's Avatar
Gimmie my points Biatch!
My tail light on the rear was busted. It was a bulb that somehow shorted out and melted the plastic in the socket. It melted it bad enough that the two + and - was touching. That caused the short. I just had to replace the socket.
Old Aug 19, 2004 | 02:15 PM
archie2004's Avatar
I'll check out the mount. Thanks for your reply.
Old Aug 19, 2004 | 03:19 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
yeah look at the socket that happened to me, i got a replacement at a local pick and pull and problem fixed
mada51589
Jan 9, 2025 04:40 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
PortlandRL
Sep 14, 2015 12:01 PM
Ny1718
Sep 11, 2015 09:21 AM
theinsvnity
Sep 10, 2015 10:22 PM
