bleeding the brakes
Old Sep 22, 2005 | 10:32 PM
$peed])emon's Avatar
Si says "shut the fuk up"
bleeding the brakes
do i bleed the brake fluid on both rears, or can i just bleed through one side??? and how do i get the air out of the system?
Old Sep 22, 2005 | 10:38 PM
dansu's Avatar
Start at the caliper furthest from the master cylinder and work your way up. So it should be rear right, rear left, front right, front left. You need two people to do it unless you have a power bleeder.
http://www.stoptech.com/tech_info/wp...edbrakes.shtml
Old Sep 22, 2005 | 10:40 PM
the second person is to pump the brakes rite?? also how do i get the air out of the system?
Old Sep 22, 2005 | 10:42 PM
Smalls's Avatar
Insert Sarcasm Here
thats what bleeding the brakes is, getting air out
Old Sep 22, 2005 | 10:44 PM
Smalls's Avatar
Insert Sarcasm Here
someone has to pump the brake pedal then hold it down. did you even read dansu's link?
Old Sep 22, 2005 | 10:47 PM
just alittle urgent...reading rite now actually...thanks for the link....my real problem is that i have a leak around my left rear caliper...somewhere around the bolts where the lines meet.....can i just tighten the bolt so it stops leakin???
Old Sep 22, 2005 | 10:51 PM
Smalls's Avatar
Insert Sarcasm Here
maybe....it depends. Inside that bolt that holds the line on the caliper are two washers, which are there to prevent leakage. If one of those two washers is messed up, you might have to replace the whole caliper.
Old Sep 22, 2005 | 10:56 PM
so should i even bleed the system?? or just top it off?
Old Sep 22, 2005 | 11:01 PM
Smalls's Avatar
Insert Sarcasm Here
if your pedal is mushy, then yes, bleed the system. If it feels you have to push the pedal really hard to stop, then yes, bleed the system.
The thing is, if fluid is getting out, it is possible that air is getting in.
Yes, bleed the system. Then top it off
Old Sep 22, 2005 | 11:06 PM
ok, thanks for the info
Old Sep 22, 2005 | 11:12 PM
one more quick question....do i really need that plastic tubing that the site dansu mentioned??? can i just bleed the system like 5 times to make sure that there are no more air?
wilp99's Avatar
you can get replacment washers just ask for the caliper (front or rear) banjo nut washers. and you can get them at autozone.. and anytime there is a leak you need to bleed the brakes. cause for every drop of fluid that comes out just as much air gets in. try to tighten the nut first. if its just loose then tighten it.. and bleed that caliper, and if you get air free fluid within the first 2 pumps, then you should be aiit and the others dont need to be bled.
Old Sep 22, 2005 | 11:15 PM
hmmm...im not to familiar with the "banjo" nut washers...how would i install them?
how do i kno when the fluid is "air free"?
Old Sep 22, 2005 | 11:40 PM
dansu's Avatar
you stop when you see that new brake fluid is coming out of the bleed valve. The plastic tube is there to prevent brake fluid going all over the place. It's definitely possible to bleed without it, but it's a good idea since brake fluid will eat through paint.
Old Sep 22, 2005 | 11:51 PM
ajtcl's Avatar
Peace, Love & Acura
caustic shit that stuff is.
Old Sep 23, 2005 | 12:24 AM
saiko_cl_duck's Avatar
evil friken stuff it is, makes skin itch like crazy
GWEEDOspeedo
Jan 15, 2016 10:39 PM
rockyboy
Oct 2, 2015 10:45 PM
polish_pat
Sep 30, 2015 12:22 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
