BENZ Flip Key for Acura!?! Would this work!?
DamnThisHobby'sExpensive!
Hey, so u think this would work..?...just get the blank key cut to match your OEM key and u think u'd be able to program the remote too??
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2446599645
heres another with the ACURA logo on it...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2447029065
A-CL Totaled Member
The second one definately wouldnt, the first one doesnt say if it has a transponder or not. I would hope so for the price but i dont think anyone makes transponder flip keys.
its paid for
you would have to still use the factory remote, unless you could reengineer it to work. but that would only fly for the 97's since they don't need the transponder.
Commander in Chief
They make what is called a transponder by-pass for remote starter systems. I'm sure this could easily be used to work with the flip key. However, the bypass is generally expensive and you would have to use one of your original keys to code it, or, You may need to leave the original key inside the dash, because the key itself has a resistive value to it that the electronic ignition recognizes. The whole setup would probably cost you 50 bucks or so to install.
Commander in Chief
Originally posted by proaudio22
The "bypass" used in remote starts in a correctly coded key close by in the dash...
These flip keys look :ghey: tho. Go buy a Benz or a VW if you want one...
tman570
06-11-2019 07:56 AM
nanos
11-12-2015 08:41 PM
asahrts
09-04-2015 05:55 PM
