Battery
Battery
My factory battery finally went out and my father had amaco put in a new one but my subs dont hit as hard do you think a yellow top optima would fix this problem?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
The optima will help you not kill your battery or alternator, and give you a more constant current. Also, check your connections to the battery terminals.
Originally Posted by ninjaturtle420
Optima batteries are the shit!
I would seriously consider upgrading your alternator if you're running a power hungry system
Bosch has a new line of high - ouput alternators with an application for the 94-97 Honda Accord with an output of around 180 amps.
I would spend $$ on that first in addition to upgrading the "big 3" (do a google search on this !), then spend $$ on the Optima and Cap, etc.
If you're just running a small system ( a single 10" or 12"), a Cap might help a bit
remember....you're system is only as strong as it's weakest link !
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
Didn't even think of this till now, if you got a new battery, check your eq settings, cuz all your eq and bass settings were erased when the battery died.
But I still recommend the optima, they are a godsend for systems
A cap as well, they help your amp and battery a LOT
The cap will save your alt's voltage regulator in the long run, but if you want to listen to your friend, I strongly suggest that you look at the heavier alt. The CL comes with either a Denzo or Delfi alternators. Both are rated 80amps. You should look at some of the 180 to 200 amp alts if you are gonna thump without a CAP.
i have installed/ had systems in my older cars, and am planning on installing one in my CL when i get the cash....
first of all, what is a cap? i have never heard of this....
also, for those who have systems in thier CL's, does the trunk rattle alot with your subs????
that is one thing that i can't stand, its my pet peeve i guess.... i had 3 10' MTX thunder 6000's in my old Acura Vigor and it rattle so much ( not only the trunk but also the metal that were inbetween back seats and also the brackets that held the back 6x9... i almost hated it because of this) I even got the trunk of the vigor dyno-mated at a local car sound shop and it didnt really help
just wondering so i can know what to look for when getting a system....
i am thinking about just gettting a single JL 10W3...nothing to big
(Mid-Atlantic)
(Mid-Atlantic)
I'll kick that idea around and see how it sounds with a new battery and how much this alt is gonna be. I'm kinda weary about doing all of this before the dynomating but o well, my system sounds alot better with the window cracked for some reason.
"big" was the 6 - JL 15W6's and no 3rd row seats in the lowered Astro van you see parked on the street in my avatar picture....i never knew roof panels could have flexed that much LOL
MetalGearTypeS
08-29-2016 08:28 PM
