awesome cheap fix
awesome cheap fix
so today i was rummaging thru some old ass problems and fixes threads and stumbled across the one about fixing vibration at idle. well after checking all my motor mounts and concluding that they're fine i did the idle relearn by unplugging the 7.5amp "Back-Up" fuse in the underhood fuse box and leaving it out for 20 seconds and then letting the car run until the fan came on twice (if you do this relearn procedure make sure all the electronic features are off. the lights, climate control and radio etc. don't ask me why). and after that my slight but very irritating vibration was completely gone. i'd reccomend checking the thread out if you have that annoying vibration at idle https://acurazine.com/forums/1g-cl-problems-fixes-71/how-fix-2-2-2-3-vibration-idle-689195/
Nice to see a new member searching and researching older threads, glad you found your answer, you should find the answer to most issues about your car on here.
SidhuSaaB
May 30, 2020 12:40 AM
