automatic is boring, how bout typtronic?
Saving $$$ for something
I'm saving for this turbo kit, and the transmission won't hold, neither will the torque converter. But my question is "does anyone know the price of the level 10 typtronic setup?"
Swap your transmission with a 5 speed. Either get an accord/CL 5 spd or even better a prelude 5 speed with lsd. How much H.P. do you think your going to get by putting a turbo kit on an f22a? I doubt you'll be able to put up more than 250 H.P. Theres only so much you can do that engine. If you were to get an h22a and then do a turbo setup you can easily put up #s around 400 H.P. Any way you put it around theres just so many more parts that are made for the h22a vs. the f22a or f23a. Another fact you should consider is that you won't be able to boost more than 7 lbs. or so on the f22a. If you were to properly build up an h22a you can boost it past 15 lbs. Sorry if I went a little off topic but it seems like your very interested in geting a turbo and I thought you should be advised of what your getting into. Good Luck
Scooby Guru
Typtronic sounds like something BMW would offer that would automatically compose emails for you while you drive and narrate.
I think they mean Tiptronic, right?
Hold on a sec.
Last time I checked tiptronic let you change gears by pushing a button but without having a clutch. Sort of like the automatic alternative to a stick car.
Pham Alvan
03-16-2016 09:17 AM
guyvelella
09-30-2015 11:02 PM
Joe Avesyan
09-29-2015 03:57 PM
