anyone know anything about the JDM J30?
SSM Accord V6 6 Spd
that would be a fucking AWESOME swap. here's some info on the honda inspire (the japanese accord) engine:
Code J30A
Manufacturer Honda
Type V-6
SOHC
24 valves total
4 valves per cylinder
Main bearings
Construction
Bore × stroke 86.00mm × 86.00mm
3.39 in × 3.39 in
Bore/Stroke ratio 1
Displacement 2997 cc
(182.888 cu in)
Unitary capacity 499.5 cc/cylinder
Compression ratio 10.50:1
Fuel system Honda PGM-Fi fuel inj.
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter Y
Max. output
(JIS) 249.4 PS (246.0 bhp) (183.4 kW)
@6000 rpm
Max. torque
(JIS) 296.0 Nm (218 lbft) (30.2 kgm)
@5000 rpm
Maximum rpm
Coolant Water
Specific output 82.1 bhp/litre
1.35 bhp/cu in
Specific torque 98.77 Nm/litre
Code J30A
Manufacturer Honda
Type V-6
SOHC
24 valves total
Main bearings
Construction
3.39 in × 3.39 in
Bore/Stroke ratio 1
(182.888 cu in)
Aspiration Normal
Compressor type N/A
Intercooler None
Max. output
@6000 rpm
Max. torque
@5000 rpm
Maximum rpm
Coolant Water
1.35 bhp/cu in
SSM Accord V6 6 Spd
Wiring up the i-vtec could pose a problem, but nothing that isn't fixable. Another problem is our tranny not handling an extra 40hp at all times.
ENGAGE MY VTEC BABY!!!!!!
Originally posted by DanMan1464
whats ghander? is he someone on the board?
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
:noob:
had to say DanMan
CLpower used to be ghander before he became a moderator
i think that engine ghander will be had to use since the i-vtec, different wiring, but thats why it comes with the ecu but i wonder if our wiring matchs up, ask the seller for a pic of the ecu
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
Originally posted by baka_t
My bad, didn't see it. If its a manual ecu, then you could prolly find an 6sp and make it work. Do it ghander make us v6's proud.
well the 6 speed trannies have their OWN ecu on them. So i'd have to get that ecu w/ the tranny.
Originally posted by dustbuster4
I wonder if this is the infamous J30A3?![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Scott, go for it!!!!
i'm waiting to hear back from the seller
:noob:
had to say DanMan
:noob:
had to say DanMan
let's get this straight, CLpower use to be CLpower then got banned and became Ghander, then switched back to CLpower
k series are easy into a hatch though, they already have the mounting kits and harness's to make it a bolt in project.
Big Block DOHC Type-R
That jdm 3.0 is going to sit opposite of older 3.0's because it rotates clockwise. I would talk to Todd at Hasport and see if he has any suggestions. If you have to fab some mounts I dont know if it would be worth it. $$$$$!
my mechanic builds hasports race cars. I'd be able to sit down w/ them and work w. them on it. I didn't know that it spun the opposit though. Thanks for the heads up mark.
I'm preaty sure all i-Vtec's rotate clockwise, even 3.0's. It's weird to pop the hood of new honda's and see the intake manifold right in front of you instead of the exhaust manifold.
The movement has started
*Edit to my last post, guess it is an I-VTEC. Apparently I-VTEC is totally different on the japanese market V6, as VTC wouldn't work too well w/ sohc vtec. Has to do w/ variable cylinder technology I think?
yea, like the I-Vtec written on the motor didn't give it away brian
is that the j30a3 though? Is it what is in your guys accord B?
Nah, its some other variant of the J30.
I didn't look at the link, when I did, figured I better check that out. Was associating I-VTEC w/ VTC at first, and I knew no J series had that.
roomate has a CL too
I was researching and this is what I came up with
http://www.globalcar.com/datasheet/H...nspire30TL.htm
the 03 Inspire has this engine.
so when looking into the swap I would say TL mounts...
someone found that on v6performance.net, its supposedly NOT a good swap. http://www.v6performance.net/forums/...ighlight=ivtec
2600lb CL
Yea I emailed the guy asking some questions which he didnt answer. I asked him if it was the J30A1, J30A2, J30A3, or the J30A4 motor just to see what he'd say to that (just seeing if he knws his shit), then I asked him if the original tranny came with it, and if not, then what was the orginal tranny, auto or manual. Lastly I asked him what the stats on the motor was....his exact reply was (with the spacial error and everything, lol):
IT DOES NOT COME WITH TRANSMISSION.IT SHOULD FIT BASICALLYBUT WE DO'NT INSTALL HERE,ONLY TOLD BY CUSTOMER.
THANKS.....................TOM.................... ..888-886-8898..........................
well that's completely understandable. These places just get TONS of motors and sell them. They are strictly motor shops. I remember when the bseries first started showing up, the motor shops had no clue what they were.
