any difference between 96-97 and 98-99?
Old 04-02-2009, 12:29 PM
  #41
Skuuuurrrrrt!
GhettoNinja06's Avatar
Originally Posted by SpAzZy
my 97 3.0 CL has heated mirrors and heated seats. =)
too bad my driver heated seat hasn't worked for the last 4 years. its ok, i'm not a fan of heated seats. makes me feel like i just shit myself
My drivers side seat heaters didn't work either till I swapped the power seat track when it took a dump. Might be your relay box in the power seat track.
Originally Posted by on1wheel01
Jjst thought I'd throw it in here my 97 premium has the heated mirrors(switch is at controls). I have always wondered the diff between years. So the tranny is diff with 97 and the following years but all years are garbage correct? I do wish my side skirts we're painted(gonna take care of that).
Correct. All the trannys are garbage all the way up to the 2nd gens...
Old 04-02-2009, 01:37 PM
  #42
SpAzZy's Avatar
Thanks for the info but winter's over and I'm 90% sure I'm going with an RSX interior swap soon. I might try to rip out the heated seat components and put them into the RSX seats though.. if I do, I'll make a DIY.
Old 04-02-2009, 03:11 PM
  #43
bigT's Avatar
Originally Posted by davzilla
oh for sure you guys in the states have heated mirrors, just saying it seems optioned more up here.
ever notice that the vents open up when you pop the sunroof?
I never noticed that one before.
Old 04-02-2009, 03:34 PM
  #44
Blazin Si's Avatar
Which vents?
I've noticed the ones in the center (above the climate controls) blow air when the a/c is on. When you're using heat, it only blows out the side vents unless you set it manually.
Old 04-02-2009, 03:42 PM
  #45
davzilla's Avatar
go for a drive, turn off the climate control, notice the air coming through the vents. now pop the sunroof and the airflow through the vents increase.
Old 04-02-2009, 04:15 PM
  #46
Blazin Si's Avatar
I'll try that out tonight.
Old 04-02-2009, 09:04 PM
  #47
6spd FTW
Tehvine's Avatar
Unless you turn on recirculate, then nothing comes out.
Old 04-03-2009, 07:41 AM
  #48
Kiwi///girL's Avatar
Just over the square to move the mirroir, beside the switch to select right or left. You have a kind of switch On/Off for the heated mirroir!
On the 6thgen Accord, the switch have a red led on it to let you know if its heating or not. On my Cl, i do not have this led. Maybe it came later or mine is busted
Old 04-03-2009, 08:12 AM
  #49
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,478 Likes on 3,071 Posts
it lights up orange when it's on
Old 04-03-2009, 10:04 AM
  #50
davzilla's Avatar
and it has to be cold out kiwi, it only turns on/lites up when the climate control is reading cold enough outside.
Old 04-03-2009, 10:31 AM
  #51
Dicorp's Avatar
thats stupid.
the one on my prelude works always, usefull whens its spring time and mirrors fog up.
Old 04-03-2009, 10:53 AM
  #52
DoubleSh0t's Avatar
I've never had mine -not- turn on. I use it when it rains to evaporate the water and it's always worked.
Old 04-03-2009, 11:20 AM
  #53
Myxomatosis's Avatar
good hint, I've got the same problem. My passengers love the heated seat, however I loathe them for their show of decadence. Never really needed the mirrors heated but I turn them on, just in case they do something.
Old 04-03-2009, 12:13 PM
  #54
davzilla's Avatar
Originally Posted by Dicorp
thats stupid.
sweet, guess it's just my car then. guess i'll have to play with it, cause that was the conclusion i came to.
Old 04-03-2009, 12:36 PM
  #55
Dicorp's Avatar
in my CL they never turned on either cause i never drove it in the winter. during the summer, it wouldn't come on. so i guess ur right. CC dependant.
Old 04-03-2009, 01:24 PM
  #56
(Mid-Atlantic)
it's all based on the cc
Old 04-03-2009, 02:52 PM
  #57
CL in lawnmower status
mitch14's Avatar
hmm... mine must not be working then, i've never seen it light up before, and when i've pressed the button to get the ice off the mirrors i thought it didn't do anything.
guess i'll have to check my fuses and go from there
Old 04-03-2009, 10:33 PM
  #58
davzilla's Avatar
ok, i played around with it tonight while i was working. it was cold out, like 3-5 degrees so i can't verify the CC part, although i turned off the CC and it stayed on. what i did notice was the switch doesn't seem to lite up until the mirrors get warm.
i find it amusing that we're actually having a discusion about heated mirrors
Old 04-03-2009, 10:39 PM
  #59
Skuuuurrrrrt!
At least it's something new..
Old 04-04-2009, 02:44 AM
  #60
incredulous1's Avatar
oh wtf, so thats why i dont know about the heated mirrors. my cl doesnt have that button, so im assuming i didnt know. oh well. basic model ftl. =)
Old 04-04-2009, 10:53 AM
  #61
(Mid-Atlantic)
Man, I hope you detail that interior, if my door handles looked like that I would probably
Old 04-04-2009, 05:31 PM
  #62
Speaking of lights. My heated seat that doesn't work, does light up and my gas light does not work. I learned about the gas light the hard way, it was the first time I've ever run out of gas in my life.
Old 04-04-2009, 06:32 PM
  #63
SpAzZy's Avatar
the gas light is sensitive too. its dull when your not really that low, but when you get really close to running out it glows really bright. i don't trust the light anyway, i always base it off my trip meter on when i need gas or when i'm really cutting it close to empty.
my heated mirrors light stays on no matter how hot or cold it is. never seemed like the CC ever controlled it. if i click the button in to turn them on, it always lights up.. for the longest time i left them on all year round cuz i liked the color it glowed when its on.
Old 04-04-2009, 07:09 PM
  #64
DoubleSh0t's Avatar
You should never see that gas light. Never let your tank get below 1/4.
  #65
Blazin Si's Avatar
I don't think my gas light works. I've had the needle below E and still nothing. It hasn't lit up in the 4 years that I've owned the car.
Old 04-04-2009, 07:28 PM
  #66
(Mid-Atlantic)
Why not, it has a 2 gallon reserve?
Old 04-04-2009, 07:56 PM
  #67
davzilla's Avatar
yeah seriously, it's a 64 liter tank and if i fill up at E before the light comes on i put in like 45-50L.
the CB7 was the same too. i drove 800kms all highway on one tank once and not speed limit highway either, lol.
Old 04-04-2009, 08:17 PM
  #68
Anhedonia's Avatar
when i generally fill up i put 13-14 gallons in... around a quarter tank. my light only comes on after ive gone through about 15-16 gallons..
Old 04-04-2009, 08:57 PM
  #69
yeah why not?
Old 04-04-2009, 09:15 PM
  #70
Blazin Si's Avatar
Originally Posted by Euro925
yeah why not?
I think your fuel pump has to work harder to supply the engine and it causes it wear out faster. More fuel keeps it cooler as well.
I could be wrong.
Old 04-04-2009, 09:51 PM
  #71
oh. well ive been driving it to almost empty and only been filling up to a half tank lately to keep the weight down and get better mpgs...
Old 04-04-2009, 10:51 PM
  #72
DoubleSh0t's Avatar
I could be wrong.
You are correct, also any dirt at the bottom of the tank will be sucked in to the fuel lines and in to your fuel system. This isn't supposed to be an issue anymore because fuel is supposed to be filtered better, but I don't trust that.
Old 04-04-2009, 11:22 PM
  #73
davzilla's Avatar
um, isn't that what a fuel filter is for?
  #74
Skuuuurrrrrt!
What gas light are you guys talking about?
edit: nvm, I guess mine doesn't work... Probably the only thing that doesn't work on the car.
Old 04-04-2009, 11:32 PM
  #75
DoubleSh0t's Avatar
Just passing along info from guys who build engines for a living.
Old 04-04-2009, 11:57 PM
  #76
6spd FTW
Tehvine's Avatar
Yeah, running the tank to near empty is no bueno for the pump. Less fuel to keep it cool.
Old 04-05-2009, 12:54 AM
  #77
davzilla's Avatar
and if i had a built engine i would agree with you, but a stock honda motor is pretty dummy proof. Unless it has dohc, lol.
also i was kinda being sarcastic but i'm tired and forgot the posting in red thing you guys do on here.
Old 04-05-2009, 02:47 AM
  #78
(Mid-Atlantic)
meh
Old 04-05-2009, 11:29 AM
  #79
hey, like I said it's the first time I've ever run out in my life Another thing about this car, which I at least remember it being the opposite in my other cars, the gauge goes up when you accelerate. I know in my camry it only went up when you braked. It doesn't seem like a big deal, but it is if you're below 1/4 tank.
I fill the car completely once and a while but usually put 5 gallons in, since it fits my routine, with my 50 mile round trip commute. 17 gallons is a lot of weight.
yeah, I shouldn't be running that low, but as mentioned it is a honda, I already own a car with bad fuel pump issues...taurus, had to already change it once, since the wife doesn't seem to understand this concept of not running on E.
It shouldn't be done often, but by the number of people with the same problem as me, just in this thread, I think we might conclude there's something up with the warning light in the first gen CL.
Old 04-05-2009, 12:20 PM
  #80
Anhedonia's Avatar
its because our fuel gauge is mechanical and not digital. ever notice when ou park on a hill you have a different amount of gas then when your flat? its a mechanical bobber, much like one from a toilet that tells the gauge how much gas is in the tank. if you have a 1/4 tank and park facing uphill on a relativley steep hill, chances are your going to have a gas light on when you get in the car.
Quick Reply: any difference between 96-97 and 98-99?
