Another Rotor ?
CL- SMOOTH
Another Rotor ?
Is it wise to use factory brake pads on my crossed drilled slotted rotors by brembo, I haven't installed them yet. I was thinking that if not a good idea i'll prob go with axxis or aem. which is better??
A-CL Member
dustbuster4, i've got a question for you... i would look around, but the search function is disabled... how is your brake pad/rotor combination in terms of noise? any squeekin? how's brake dust compared to oem pads on oem rotors?
A-CL Post Whore w/N2O
I would say that the brake dust is about the same (maybe a little more; but not much).
I compulsively clean my car at least once a week, so the brake dust really never builds up.
A-CL Member
i suppose i should've posted this earlier, but drewha174, no, it's not a bad idea, though your braking performance wouldnt be as good with the oem pads than if you went with the axxis or aem pads.
CL- SMOOTH
[QUOTE]Originally posted by zeeshan282
i suppose i should've posted this earlier, but drewha174, no, it's not a bad idea, though your braking performance wouldnt be as good with the oem pads than if you went with the axxis or aem pads. [/QUOThank you Z, but what about if I were to install the rotors and keep the oem pads, "can't wait for a couple of days for the aftermarket pads" Then change the oem once I get the aftermarkts. Will this affect the rotors??? Again thanks...
A-CL Member
[QUOTE]Originally posted by drewha174
nope, no problems there. the rotors should be fine.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
