alloy rims leaking air??
Turn Signals are good!
have the tires re-mounted... and when they do, have them inspect the rims for corrosion or any damage that maybe causing the leaks.
if all else fails... use fix-a-flat or get new wheels.
Do NOT use fix-a-flat. That shit is meant as a short-term solution for flat until you can have it fixed or replaced properly. It'll throw the wheel way out of balance. Have them re-mount. They should use a sealer along the edges. If that don't hold then the probably needs fixing.
cycdaniel
12-17-2019 10:58 AM
09-15-2015 06:44 PM
