Alignment?
Old Nov 9, 2009 | 08:49 PM
peters_sweet_CL's Avatar
Alignment?
I have a little issue...my 97 3.0 seems to pull to the right when i let go of the steering wheel. Then on the highway, its a little shaky. I noticed that if I let go of the steering wheel while slowing down, it moves right and left like a vibration very quickly. The tires have been rotated and balanced...do you think its time for an alignment? I just flipped 90k miles.
Old Nov 9, 2009 | 09:13 PM
Shadoh's Avatar
Sounds like an alignment is due, when you're driving straight is your steering wheel centered? Or is it a little bit to the left? Mines off by like 2 inch to the right and pulls to the left if i dont hold it off center... i need an alignment.. i think you do too :p
Old Nov 10, 2009 | 08:20 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
alignment, or your rotors are starting to warp if you notice the shaking on stopping
Old Nov 10, 2009 | 08:29 AM
Mach30SiR's Avatar
Bagel Bomber
I'm thinking its both, alignment and rotors.
Old Nov 10, 2009 | 10:03 AM
hOnU's Avatar
Da HoNu
its your rotors! i had the same thing happen to me! make sure you get them resurfaced or new rotors!
Old Nov 10, 2009 | 12:36 PM
DjXtC34's Avatar
lol i changed everything. i had warped rotors and i did the alignment due to all the ball joints being replaced. if i where you. change w/e you think needs changing before the alignment because every time you touch something the alignment gets thrown off again.
Old Nov 10, 2009 | 01:26 PM
MoSp33d's Avatar
N00berator
^ agreed with everyone! same thing happened to me...so i changed the rotors and then i went for adjusting the alignment..
Old Nov 10, 2009 | 02:43 PM
I just got the rotors done last year? after a new transmission and a shitload of other stuff, if its the rotors, im saying bye to the CL.
Old Nov 10, 2009 | 03:17 PM
Mach30SiR's Avatar
Bagel Bomber
were they resurfaced or replace rotors? Resurfaced rotors might warp quicker. Rotors are only 50 bucks each on Advance Autoparts, pick up a few and do them yourself. Its a fairly simple job especially if you had them done last year and that little screw holding on the rotor isn't rusted on.
Old Nov 10, 2009 | 06:46 PM
It doesnt shake when im braking, just when i let off the gas and let it slow down by itself...the rotors were changed last year and they just did my axles/transmission last week, so maybe that threw it off?
Old Nov 10, 2009 | 08:14 PM
Mach30SiR's Avatar
Bagel Bomber
and nothing under acceleration? Does this only happen at a certain speed range? What gears?
Old Nov 11, 2009 | 08:12 AM
(Mid-Atlantic)
Yeah, changing axles would def throw off your alignment
Old Nov 11, 2009 | 01:48 PM
yea usually during acceration, i have to hold my wheel more to the left to go straight...most of the time its pretty much near center...on the highway or going about 60, you can feel a little bit where its usually smooth. the dealer wants $69.95 to do it, should I just get it done?
Old Nov 11, 2009 | 06:38 PM
Blazin Si's Avatar
You might have one of your wheels unbalanced even if you just had them done recently. If the tire shop used the "stick on" weights, they might have fallen off.
I've never had warped rotors cause the steering wheel to shake under acceleration or coasting speed. Sounds like the alignment is off and possibly a bad tire. There's certain types of tire damage that can cause vibrations in the steering wheel.
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
Zonian22
Nov 14, 2015 01:20 PM
TxRzrBk
Sep 17, 2015 01:07 PM
