abs activiation??
abs activiation??
ok today my ABS activated and i was wondering, is the pedal supose to loose all pressure and sink down to the floor while the system is activated or does it stay with pressure cause mine looses all pressure and sinks to the bottom and all i heard is tires burning outside!!! is this normalL??
I would get ur abs system checked usually if you inguage the abs the pedal will loose some pressure but not all pressure just a little less then normal and the pedal will pulse also tires burning mite be a sign that its locking..mite be that one of the abs valves are sticking or your abs went out..Is the abs light on?
mada51589
Jan 9, 2025 04:40 PM
Jamus22
Jun 11, 2023 10:08 AM
