99 CL 3.0 got Stuck in Park
Went to run some errands today and my 99 CL 3.0 wouldn't shift out of Park. I then pumped the brake pedal a bit and finally got it into gear. This happened 3 times today and has never happened before.
I did a search on the forums and it seems that it could be caused by a number of things. My brake lights appear to be working so I think my problem may be similar to the post listed below: https://acurazine.com/forums/2g-tl-problems-fixes-117/stuck-park-601667/ I remember receiving a mailing about a recall regaring a recall which I haven't gotten around to doing. I'm not sure its related to my problem above. Anyone else experience this on their CL? Any other tips? Thanks. |
Also I tried to remove the small cover on the shift plate and to my surprise there was no key slot.:mad: It was just an empty cavity.
Originally Posted by zyx345
(Post 10034964)
You should be able to slip a small screwdriver in there toward the bottom side of the hole to disengage the shift interlock as can be seen at 1:08 in this video. http://www.youtube.com/watch?v=E5JDPDT1FfE |
just push that little white piece of plastic down dude.
the recall should fix it for you.
