3.0 mpg?
3.0 mpg?
What do you all average highway and city?
I have a 280 mile weekend commute, and its all highway so im hoping to get high 20s maybe 30 mpg?
Originally Posted by DoubleSh0t
Since it's winter, I get around 18-19 MPG. A lot of that is highway, but there's some mixed driving in there too.
![what](https://acurazine.com/forums/images/smilies/what.gif)
edit: when youre on the highway do you do 65 or speed?
I don't think my car is the standard though. I get terrible mileage in the winter because of the additives in the fuel they put in. I have to use Hess gas around here, if I go anywhere else it's worse and I have to use 89. During the summer w/ my intake I get around 250 miles on a tank (fill up at the 1/4 mark). Right now I'm stretching to get 200 at the 1/4 mark.
Edit: The highway I use daily is 55, then drops to 45 between traffic lights, and finally back up to 55. If there's no traffic and I don't hit the lights, I'm usually around 55-65 all the way through.
I should also note I'm not usually light on the pedal.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
I used to get around 400 miles per tank, but that was back when my plugs, wires, intake, and all were new, but I'd still probably average around 350 or so if i had to guess
2600lb CL
those numbers actually arent that bad, considering my 2.2 gets around 280 to the tank on average, about 300-320 on all highway... then again my foot is pretty damn heavy at times..... I always fill at around the 14 gallon point when the fuel light comes on... my fuel needle is broken
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Opi
does 93 octane make that much of a difference?
Some people don't agree, but I get way more MPG with 93, that's all I use in either of my cars
FWIW: This board is lightyears ahead of acura world with response time and information
(Mid-Atlantic)
(Mid-Atlantic)
Yeah, I work in the south side and with birmingham bridge and blvd of the allies closed, I drive home through allentown, to get on 579. What color is your CL?
YOu mean allentown in pittsburgh, or allentown by philly?
My CL is white (haven't picked it up yet I gave the guy the check and he's waiting on the title, should be today tomorrow or wednesday by the latest. Im antsy as all hell.)
I'm in the Reading area, w00t for Berks CLs.
BTW I just filled up at 226.1 with 11.71 gallons but 89 this time. I'll let you know how that works out.
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
Anything above 87 is worthless, i've seen dyno #'s back to back, i've seen performance #'s back to back, and mpg #'s back to back. All done in scientific environment w/ the 3.0. I'm going to have to see if I can do some digging to find the document...i may have saved it on an old hard drive...but it was done by a test lab that did that Motor Trend (I think MT) article a few years back.
The higher octanes simply can not burn fast enough to be efficient. Run 87, you will have MORE power and will get better efficiency. This is a FACT.
(Mid-Atlantic)
(Mid-Atlantic)
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
it may be in your head (or may just be caused by the way you drive on that tank). The 3.0 Honda/Acura motor is not setup to be able to burn the high octane fuels efficiently....it hinders the motor. It's a known fact the cars run worse on the higher octane......and you'll see close to a 20 HP loss in some cases!!!
Trust me, I use to be a non-believer till I read the study and then went out and started buying 87...got much better gas mileage, car ran a lot better too.
Read Matt. 24 3-14
2600lb CL
Originally Posted by supaman8118
... yeah I wanna see the artcle... seriously
I'm going to have to do some digging, i'll see what I can bring up. Some of the info has to be on this site, but it's gotta be from atleast before 2002
Read Matt. 24 3-14
I drove from philly to VA this past sunday which was about 320 highway miles, now i'm up to 358 after driving to school and back to the apt. on a full tank of 89 oc. The needle went to empty today so i could probably squeeze out 375 safely....If it was all highway and I stayed below 80 I would get about 400 to a tank highway.
1997 2.2CL
On my wife's 1997 2.2CL, we get about 275 to 280 miles to per tankful on 87 and about 320 to 325 miles using Premium 91. Given the 20 cents/gallon difference in price, it is clearly more cost effective to get 91 (even though the manuals says 86 is fine!)
Z
I can tell you its better....... barely
I run an average 21-23 on the bright side though that's mostly city and a heavy foot, and when the gas eating A/C comes on that drops to about 20
2600lb CL
^ Jeebus. I was looking at a 2.2 manual, black with 110k miles for $3400. Looking for another beater for Cali as the Lexus will cost too much in gas over there and the Z3 makes me look like a fag. I'm looking for something in the 25mpg+ range. I do a lot of driving in SoCal.
1997 2.2CL
Originally Posted by Cocoa
^ 280 per tank, that's 20mpg assuming you fill up with 14 gallons. Someone please tell me it's better than that.
BUT, this is almost 100% city driving only ...my wife does not take her car on the highway at all.
Z
1997 2.2CL
^ Oh, well that's good to hear. Cause my Lexus gets 20mpg on the freeway! So on the freeway the 2.2/2.3 could easily see 23+mpg.
And higher too. As I recall, when I have taken it on the highway for extended trips, I have seen closer to 26 to 27 mpg. But, I have not done this in a while.
Z
yeah on the freeway im pulling 320s easy, doing the math thats 23s, and I cruise at an average of around 75-80s since I always travel at of hours, so at an average 65-70 cruise id reckon 24-25 MPGs + the manual transmission on that one as opposed to my slushie will probably make a small difference too, maybe an extra 1 or 2 MPGs
