105k tune-up...
Turtle Charged, Biotcch!!
shouldn't be any more than $200. I got mine done together with PS & brake fluid, oil,filter, brake job and some other minor stuff for $200 (The mechanic is a friend of the family.)
While you're there, look into changing spark plugs/ wires/ cap/rotor. They are easy to do so i suggest you do these yourselves. I did mine and the car idles SOOOO much better (no surging/ tach jumping).
Also there's valve clearance and timing...
If you have a 3.0 or any AT then i suggest getting a tranny cooler installed. easy to do and will prolong the autotragic's life a bit.
but from the research i have been doing for the 100k tune up the costs are ALOT more the $200...the stealership quoted well over $1000 to do it....but even if you go somewhere else it would be much more then $200( i guess unless you have a family friend to hook it up)- I was told the belt and water hose are extremely difficult in our engines to change...and the cost is in the labor, not parts....
as i said i might not know what i am talking about...but i am right at 100k myself and am starting to look into doing the major tune-up but i am thinking of having to spend closer to a grand not $200
please prove me wrong because i will be very happy if i am wrong!
its well worth it to put the money into these engines because you know they will least another 100k! especially if you have a manual and don’t have to worry about the auto going dead on you
When i got my car done i got the timing belt package, witch includes the timing belt, water pump and drive belts. The bill came to about $950 but i was able to talk them down to around $500 because of some miscommunication between me and the dealership. The parts were around $250 and the rest was labor.
Also there was a recall for my 97 3.0cl (other years my be included) in witch i got the spark plugs, wires, rotor and cap replaced for free.
Like i said, the mechanic is a long time friend of the family. I bought the parts (belt, hoses, etc) needed cheap from the internet and have him installed/serviced everything for $200.
I did the other stuff like starter, spark plugs, wires, cap, rotors, rear brake rotors/pads.....myself so i saved a lot of money.
Another thing, Vietnamese shops are cheaper than almost every other shop...
Matt
Originally Posted by natesezgoblue
besides replacing the timing belt and water pump what else do they do? how much should i expect to pay?
your labor cost alone may be over $200.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by STL+3.0CL
More than $200
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by tman89544
What is the bare minimum you should do? I recently just hit 90k so i've got to think of a tuneup soon.
NighthawkBlue
04-14-2008 10:14 AM
