Wind noise from sunroof when sunshade open
Old 01-06-2009, 07:13 AM
MDXin's Avatar
I have noticed a lot of wind noise from the sunroof area when the sunshade is open. I've done searches for this but haven't found anyone with a fix. I have adjusted the position of the sunroof and there is no improvement. also pushing up on the sunroof doesn't change the noise. So I have determined that it is not coming from the sunroof, I think the noise has to be coming from somewhere else like a rear side window or the windshield. Does anyone have any ideas on this? I have a relative that owns a auto glass shop, I may sit in the car and have him blow compressed air around all the windows to see where it is coming from.
Old 01-06-2009, 07:39 AM
Moderator Alumnus
FiftyFive's Avatar
Hm, never noticed, next time i jump on the highway i'll see if i can replicate. Does it only happen above certain speeds?
Old 01-06-2009, 08:57 AM
MDXin's Avatar
Yes, its only above about 40 mph that you start to hear it, up to that it may be to quiet to hear. It doesn't start all of a sudden but kind of builds the faster you go.
Old 01-06-2009, 09:39 AM
Moderator Alumnus
FiftyFive's Avatar
Hm, you sure its just not wind turbulence from the open sunroof? Can it be resolved by getting a sunroof visor?
Old 01-06-2009, 10:15 AM
MDXin's Avatar
the sunroof is closed. the sunshade is open
Old 01-06-2009, 10:51 AM
Moderator Alumnus
FiftyFive's Avatar
Ah ok, i misunderstood. I'll check to see if mine does it.
Old 01-06-2009, 11:58 AM
Moderator Alumnus
FiftyFive's Avatar
Just took it out for lunch with the sunshade open, sunroof closed, and everything else off. I got up to about 45 and heard a slight wind noise if anything. Hopefully i'll be able to check it out a little more later tonight. 2 min commute ftw.
Old 01-06-2009, 04:39 PM
007Acura's Avatar
do you have anything on your roof rack? also if you have a 07+ you can remove the cross rails which lowers noise
Old 01-06-2009, 07:55 PM
Moderator Alumnus
FiftyFive's Avatar
I believe he has an 04. I tried again got around to 50. Only heard a slight wind noise, not anything i would notice if i wasnt listening for it though.
Old 01-17-2009, 08:39 AM
frosty ride's Avatar
I've noticed the same noise that the OP is referring to when traveling on the interstate. I have the roof rack on our MDX and I'm sure that it contributes to the noise. It really is amazing how much the noise is cancelled when you do close the shade.
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
xsilverhawkx
10-05-2015 11:00 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Wind noise from sunroof when sunshade open
