Rattling sound from this valve
Old 03-22-2018, 01:16 PM
VictorTL's Avatar
Does this rattling from this valve is normal?
Old 03-26-2018, 12:51 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
That is the PCV Purge valve solenoid...
As always = "If it ticks, It must be replaced".
Old 03-26-2018, 01:14 PM
VictorTL's Avatar
hey Skirmich, how is X coming out! I hope it is all good. Did you replace your or try to fix the part? It is fixable or everything is molded in plastic? I am afraid if I spend $100 on a news part it will have the same ticking
Old 03-26-2018, 01:46 PM
VictorTL's Avatar
Skirmich, what is the purpose of this valve? Shouldn’t I get some type of error code if the valve is bad?
Old 03-26-2018, 02:09 PM
Received 8,584 Likes on 6,630 Posts
https://www.google.com/search?q=what...hrome&ie=UTF-8
Old 03-26-2018, 02:19 PM
VictorTL's Avatar
thank you sir! Much appreciate
Old 03-26-2018, 02:38 PM
VictorTL's Avatar
I found the answer. That thingy is designed to tick. It operates on a high frequency pulses, it opens and closes constantly and over time it gets louder which is normal
Old 03-26-2018, 05:59 PM
Skirmich's Avatar
It is designed to tick though because of how a solenoid actuator works but it also has an internal damper that allows (In our specific applications) for near silent operation....
If it ticks its already worn out = Needs to be replaced.
As for my X, The insurance body shop hasn´t called... I guess they are struggling in getting just the Sport Running Board plastic cap.. If they fail they will have to buy the entire SRB assembly.
Old 03-26-2018, 06:09 PM
VictorTL's Avatar
i know the internal mechanical parts are worn out but the question is it still functioning ?
Old 03-26-2018, 10:06 PM
Skirmich's Avatar
If it doesn´t throw a OBDII code its still working, Just making that annoying noise you hear.
xtmslyy00
09-12-2011 01:02 PM
golgo1972
1G CL Photograph Gallery
04-11-2007 01:28 AM
mc222
10-27-2002 09:15 PM
WebToker
06-24-2001 08:05 PM
Quick Reply: Rattling sound from this valve
