TSB 05-038: (2001-2002 MDX) Safety Recall: Front Damper Spring Corrosion
Background Some front suspension damper springs have insufficient corrosion protection. In areas where road salt* is used, these damper springs may be susceptible to corrosion. Over time, excessive corrosion can cause spring failure. In some cases, a broken spring could puncture a front tire, which increases the risk of a crash.
TSB 09-058: (2010 MDX) SAFTEY RECALL A-Pillar Bolts May Be Missing
Background The bolt securing each A-pillar trim may be missing. In the case of a side curtain airbag deployment, the A-pillar trim could dislodge and cause an injury.
