Check Transmission D Blinks
I drive a 2009 Acura MDX. Today I got the Check Transmission Light and the D Started blinking.
When I drive it gives some wierd noises too. What do i do ? |
Pull the codes... If you have Tech go to the NAV screen > Messages > Diagnostic Info and it will tell you the codes.
If you have aa Base go to an Autozone.. We can diagnose from the codes. |
No need to open a second thread in a completely different subforum for the same problem..
If you could tell us what car you drove, year , mileage, that would probably help as well. |
Dtc: P0970
The Code is P0970.
Do I have to go only to a Dealer or any local mechanic would be fine. Also any rough estimation on how much it would cost. |
Seems that there is an issue with the Solenoid C in the Trans..
How is the fluid looking? any records of maintenance? Check the ATF Level otherwise this will be a Dealership only Part... You can either try to clean the solenoid or it is malfunctioning which will mean you have to replace it. If you go to a private shop try to go to a Transmission Shop, Not a general Mechanic. |
Thank you so much for all the information.
Since I am worried to drive a long distance will try once with my nearby Gas Station mechanic first and see if I can get a quote first. Most of the solutions given on the web goes behind changing the Transmission Fluid will try that first. If i can drive to the Dealer then will check it out at the Acura Dealer too. |
(Post 16072494)
P1717 = TRS needs replacement check my thread in this forum: https://www.mdxers.org/forums/74-sec...ty-switch.html
