Change 2011 mdx differential oil and transmission oil
Sick of paying the Stealership.
I want to change the differential and transmission fluid.
What fluids do i use, do i need crush washers, a pump?
Are there any filters to change?
And how much fluid do i need.
I live in Canada and did not want to buy them at the dealership.
Thanks - i also own a 2007 rdx and will be doing the same.
help pls.
i saw that you have to use acura awd fluid - this means i have to buy it at the dealership?
help pls.
help pls.
help pls.
There are several very good write ups and DIY posts about the fluid changes, filters, crush washers, etc. Try doing a search and you will find the answers to your questions. Here are two such search with results that you can go through and find your answers.
https://acurazine.com/forums/search....rchid=13854914
http://www.mdxers.org/forums/search.php?searchid=499905
I use Honda dealer since they are 10 minutes from my house because the Acura dealer is 30 minutes and they want an appoinment every time. My MID flashed B16 message around 25k miles interval. Rear differential change cost $80. If you bring your own Acura AWD fluid, the labor is around $50. Oil change costs $20 with my own Mobil 1 Synthetic oil and Mobil 1 oil filter.
BTW, I have 2010 MDX with Tech at 45k miles now.
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
2005, 2011, acura, change, cost, differential, end, filter, fluid, mdx, oil, rear, replacement, transmission, washer
