2006 MDX Clucking in the rear.
T&S Customizing
My 06 MDX I can hear it clucking in the rear near the spare tire only going straight in Reverse and Drive at less then 5mph. I checked the spare tire cable it's tight. Acura can't figure it out. The more I think about it the more I'm guessing it's the differential mounts. I need some inputs.
Moderator Alumnus
It sounds like the differential mounts. Even Acura can't figure it out? Is there another dealer nearby where you can take it to? It should still be under warranty. Maybe your sway bar links/bushings? I had a problem with them in my TL.
Moderator Alumnus
T&S Customizing
The person that was assign to my MDX left and they brought in a Chevy service manager in and my mom took it in for that same clunking noise and that chevy guy said it was normal. I told mom to bring it home and I will take care of it so I'm taking it to the other team that fixed my Integra.
240SX is correct. There is a TSB for clunking in the rear on 2001-2006 MDX's (TSB 04-023). The TSB is for clunking when making turns though. Does yours only clunk when moving fwd and aft in a straight line?
