Why does the engine oil turn dark so quick
Old Mar 14, 2011 | 09:33 AM
AlexMN's Avatar
A-CL Member
Just as the title says. I changed the oil and filter last week and the oil is already dark (may be around 100 miles). I've only had the MDX for about a year and I always noticed this. I change the oil myself.
Is this an MDX charecteristic ?
I have a CL in which the oil stays clean for a long time before it starts to change the color.
BTW: Thanks for the DYI posts. I changed the transmission and the Diff. fluid over the weekend with no trouble.
Old Mar 14, 2011 | 12:07 PM
fxcarden's Avatar
Hmmm.....maybe the detergents are doing their job ?. how long do you go between changes ?.
Old Mar 14, 2011 | 01:02 PM
mdx_1976's Avatar
What brand of oil do you use? Has it turned dark during your previous oil and filter changes?
How many miles on the MDX?
IIRC - In my 2008, the oil stays almost new/clear for the first 1500-2000 miles
Old Mar 14, 2011 | 02:31 PM
AlexMN's Avatar
A-CL Member
There is 93K miles on the car.
I used to change when the message pops up (oil life indicator gets down to around 10%) but now I think I should be more aggressive.
I even treated with seafoam this past time.
I use the walmart brand oil and filter on both cars and it works just fine in the CL.
Old Mar 14, 2011 | 02:46 PM
bobin's Avatar
bobin
I use Amsoil 0-20 engine and a Amsoil oil filter. Its the best synthetic engine oil on the market to and there oil filter will trap engine particles down to 5 plus percent as your filters that you bust are very cheap oil filters and will only trap particles down to maybe 30 or so percent. Also city driving will change the color of the oil much more quickly.You get what you pay for is the saying. Do not want to spend the money then you can pay more later on repairs etc.
Old Mar 14, 2011 | 06:14 PM
EL_PIC's Avatar
Rich and Famous
Search and you will find ...
http://www.oilsandlube.com/oil-color.htm
Old Mar 14, 2011 | 10:02 PM
moto94536's Avatar
well the type of motor oil that you are using may turn black after 2000 miles. I think you are using mobil 1.
I have good luck with castrol syntec on my 2006 toyota camry v6. I will probably stick with 1 brand.
Old Mar 15, 2011 | 02:36 PM
dominik331's Avatar
Is the bulk oil used by Acura a synthetic blend? An Acura tech told me his dealer is supplied by Castrol and that it is supposed to last up to 8k miles between changes. Any truth to that?
Old Mar 16, 2011 | 07:49 AM
db22's Avatar
Dark looking oil, with modern lubricants, is because of a chemical reaction to the application of gasses and heat condusive to a cars engine. It is not an indication of particulate matter, retained viscosity or performance.
Old Mar 16, 2011 | 09:36 PM
moto94536's Avatar
same here. our local honda dealer use castrol synblend. Oil life is depend on the type of the driving.
I have castrol synblend oil. If you drive mostly highway, it will go 8,000 to 9,000 miles.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
