Why do I not have heat?
Old Nov 12, 2018 | 06:27 PM
COBrien's Avatar
I have a 2001 MDX that I bought in June of this year. I have had the hardest time figuring out why I have no heat. The blower motor works it just blows cold air. I have replaced the thermostat. I have flushed the heater core. The valve on the firewall is functioning. If all my coolant is flowing properly what should I check next?
Old Nov 17, 2018 | 05:53 PM
Angela Moisant's Avatar
I bought an 2002 in February and having the same problem only my heater control valve was broke. So I replaced it and flushed my core. I now have tepid air instead of ice cold when set to 90 degrees. I'm trying to find info on an inside temperature sensor but everything I search just mentions coolant temperature sensor or outside/ambient temp sensor. Have you had any luck yet fixing yours?
Old Feb 19, 2019 | 06:55 PM
Richierich97's Avatar
4th Gear
Hey I currently have a 03 mDX which is throwing only Luke warm air, checked everything and seems to be fine. Have u guys had any luck on ur issues?
Curmudgeon10
Feb 27, 2014 03:48 PM
Nexson
Aug 22, 2012 08:07 PM
CCColtsicehockey
1G TSX Photograph Gallery
102
Feb 19, 2006 12:06 AM
Shoofin
Jul 17, 2001 09:05 PM
