Where is the Navd DVD for a 2009 MDX???
Old Jan 28, 2009 | 10:28 AM
Suze05RL's Avatar
4th Gear
Hi Gang, I have a loaner 2009 mdx. My 05 RL is in the shop. I would like to make a back up Nav DVD (for the dealership, of course, in case other loaner clients have problems with the original.) I am wondering where it is located and how to eject it. Thanks for any help. All the manuals are removed form the car.
Old Jan 28, 2009 | 11:52 AM
Suze05RL's Avatar
4th Gear
Found it in owners manual section
Changing the DVD
NOTE:
The system’s database is stored on a
removable DVD. The system will not
work without the DVD. Ensure the door
remains closed at all times.
1. Locate the control unit. It is under the
driver’s seat.
2. Remove the DVD while the ignition
switch is in the ACCESSORY (I)
position or in the ON (II) position.
3. Push the OPEN button. An error
message will be displayed on the
screen. This is normal.
4. Push the Eject button. The DVD will
automatically come out.
5. Pull the DVD straight out. Hold the
DVD by the edges. Fingerprints,
scratches, or other contamination on
the playing surface can make the
DVD unreadable.
To install the DVD, make sure the white
label is facing up. Slide the DVD into
the slot. The DVD is automatically
pulled into the control unit. Make sure
you close the door.
quanaman
Jan 9, 2023 07:33 PM
Jul 16, 2017 07:33 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
