Wheel chart
Old Dec 9, 2018 | 06:23 PM
theocon's Avatar
6th Gear
Wheel chart
I need a new set of wheels for my 2009 MDX, does anyone know if the wheels from a 2018 MDX will fit? It has the same bolt pattern but the offset is different.
Thank you,!
Old Dec 17, 2018 | 03:42 PM
boostedx's Avatar
Is the offset + or - from stock? if + they shoud fit fine
Old Jan 17, 2019 | 09:11 PM
theocon's Avatar
6th Gear
Mine has an offset of 45, the ones I want to buy have an offset of 55, which I believe puts the rim and tire 10mm closer to brakes and suspension. If I bought a 5mm wheel spacer, I think it will work? Any thoughts? Need to buy asap
thanks!!
Old Jan 17, 2019 | 10:16 PM
boostedx's Avatar
Sorry just reread my previous post, wrote the opposite... you are correct, but you need to take into account the width is the wheel as well. If it is a more positive offset and wider wheel then you would need a larger spacer to clear the strut.
Old Jan 18, 2019 | 08:43 AM
R J Poseidon 6's Avatar
~HondaF1~
Check it:
https://www.wheel-size.com/size/acura/mdx/2009/
While some are not exact science - it's a great tool....
bluecarbonfiber
1G RDX Tires, Wheels & Suspension
14
May 27, 2017 05:44 PM
