Ugh, like a dumbass, I wet sanded through my clearcoat.
Old 09-27-2013, 10:09 PM
7th Gear
bourmb's Avatar
I consider myself capable with my Porter Cable buffer on scratches. However, I was tackling a deep scratch around the left/middle section on my driver door today. I filled in the scratch with clear and built it up with intentions of wet sanding it down. I then read and watched videos on what to do before attempting the act. Since the scratch was only 1" long, I decided to use a rubber eraser instead of a standard sanding block which I think led to my problem do to increased pressure capability. I started with 1250 grit and finished with 2500 sandpaper. In no time, I had rubbed through my clear in a spot the size of a nickel! I am totally sick to my stomach as my car is 6 months old AND it is Palladium Silver Metallic which is probably the hardest color to match. Let alone I will probably be $500 poorer when it gets repaired.
Old 09-28-2013, 01:40 AM
David_Dude
Acura_Dude's Avatar
Old 09-28-2013, 07:25 PM
95_993's Avatar
ooooph. sorry to hear....clear must be really thin. Can just the clear coat be shot over?
Gen4MDX (11-09-2013)
Old 09-30-2013, 04:57 AM
karlmax's Avatar
This might help fix your problem. - http://www.autogeekonline.net/forum/...clearcoat.html
Old 09-30-2013, 11:51 AM
7th Gear
bourmb's Avatar
If I cleared over the area where I sanded down to the base, it would not look right as I am sure I disturbed the metallic flakes in the base coat through sanding. I got a quote for $300 from a reputable repair shop in my area.
Mikas46 (10-01-2013)
Marcelechka
Home & Garden
188
09-11-2022 11:53 AM
RLX-Sport Hybrid
3G RLX (2013+)
27
12-07-2018 12:11 PM
Timmy18
10-17-2015 03:58 PM
polish_pat
09-30-2015 12:22 PM
Quick Reply: Ugh, like a dumbass, I wet sanded through my clearcoat.
