Timing belt on 1st gen MDX
Any of you had it done yet?
I'm about to do my mom's 2004 and my aunts 2003. Dealer quoted $850+tax for each one, I have a friend who is a mechanic charging $200 for labor. The timing belt is $55 and I've heard the V6 Honda water pumps never leak so I think we'll be leaving them in.
I'm on my 3rd timing belt in my 96 tl
^I've always done the water pump at the same time. I spoke with a master tech for Honda (who has no interest or anything to do with the service) and he said that the water pumps are usually good.....I'm still debating. It's $130.63 for a water pump from the ACURA dealer for a Honda Genuine part.
^I agree with you. I'll probably end up getting it done.
I just did a little searching online, found a site called oemacuraparts.com
Timing belt, Water pump and water pump gasket for $153 shipped!!!!! I never knew this site existed.
Got the timing belt replaced, along with the tensioner. All in all cost about $400 labor and parts together, skipped out on doing the water pump, it was in good shape. Truck runs like a top.
My mechanic said the belt was "stretched out" The truck used to shake a little bit at stop lights, just like a small misfire. We changed the spark plugs about a month ago hoping that was the issue (My friend with an 05 changed his plugs and it got much better). That didn't do it. With the new timing belt in place, there is no more hesitation or vibration. I can't wait to see if the mpg's improved.
asahrts
Sep 4, 2015 05:55 PM
