Small coolant leak (2004)
Old 11-16-2012 | 03:40 PM
jc70ss's Avatar
I saw a few drips on garage floor today. Got under it and found it is coming off of a metal looking coupler that looks like a rubber hose comes out the bottom of it and a steel bent line goes into it. I would believe that would be the water pump. Water pump was replaced with t-belt a little over a year ago at dealer. Called dealer and they didn't sound too concerned with it? Any suggestions? BTW this is on passenger side.
Old 11-17-2012 | 03:41 PM
hondaacurapro's Avatar
Can you post a pic of where the drip is coming from. When the water pump leaks it usually leaves a trail on the oil pan. If the water pump leaks bad enough, coolant can drip from the oil pan by the drain plug. There is a history of coolant passage gaskets leaking right under the EGR valve. Coolant can also leak from the radiator where the trans cooler lines go in. If you shoot out a pic, I can help you out
Mike734
12-10-2021 01:25 PM
tsx_boy
12-13-2019 08:33 PM
Avenger411
10-11-2015 03:53 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
Quick Reply: Small coolant leak (2004)
