Problem code P0420 and P0171 on my 2004 Acura MDX
Old Apr 2, 2015 | 10:19 PM
ScottMDXVtec04's Avatar
Hello I'm in need of some input I have 2 codes popping up they come and go periodically. The codes are P0420 and P0171 I bought the 2004 Acura MDX about 2 and a half months ago and check engine light came on twice with those 2 codes but the check engine light would go away the same day or the following day. I bought the O2 sensor but I'm confused as for witch O2 sensor it is due to the fact that the 04 MDX has 3 catalytic converters and 4 sensors. AutoZone did a check engine for me with there machine and on the paper it says Bank 1 cylinder 1 but every where I've checked they never speak of cylinders there located by banks and sensor location so I'm wondering if that cylinder 1 actually means sensor 1? Please help I'm at a lost. I'll post a picture of what I've been going off of. Thanks in advance.
Old Apr 3, 2015 | 03:15 PM
Lloyd10977's Avatar
7th Gear
My Chilton's manual for 2001-2007 indicates:
P0420= Catalytic efficiency below threshold(REAR CYLINDER HEAD)
P0171= Fuel system too lean (REAR CYLINDER HEAD)
That would cover cylinders 1, 2 and 3 (closest to the firewall), so the upstream O2 sensor on that side should be the one that should get your attention.
mada51589
Jan 9, 2025 04:40 PM
holografique
3G RLX (2013+)
Sep 6, 2015 08:20 AM
elietania
4G TL Problems & Fixes
Sep 5, 2015 06:52 AM
NSolace
Sep 3, 2015 08:14 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
