Part Numbers for 3rd & 4th gear solenoids
Great Northerner
Does anyone happen to have the part numbers for the 3rd and 4th gear solenoids for a 2007 MDX automatic transmission? Or point me in the right direction?
Thanks in advance!
Thanks in advance!
28600-RAY-003 X2
28610-RAY-003
The first one with X2 one is for second gear and one is for fourth, they are the same part number so might as well replace it while your in there. Just an fyi, they are a pain to install, very tight space, you'll need a 22mm socket and remove the intake. I'm glad that your doing this to your mdx, many people don't realize that this will help prolong the life of the tranny. Thankfully I learned about this from the TL threads.
28610-RAY-003
Great Northerner
Thank you very much, that's excellent info. For anyone that needs these sensors you can find them here:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
They are part numbers 11 & 12. As usmarinedelta said not many people realize how new ones will prolong the life of the transmission. If you experience a jerkiness in shifting at lower speeds (i.e., 30MPH) I hear that replacement of these sensors have fixed that issue too. I found that out on the 3rd gen TL forum.
darksky
09-05-2015 03:11 AM
