which one should use for transfer fluid?
The manual page for 2011 MDX says transfer fluid should use SAE 90 or SAE 80W-90, GL4 or GL5, confuse me, which one i should buy? thank you very much.
Last edited by EE4Life; 05-01-2017 at 07:58 PM. Reason: Corrected year from 2001 to 2011
Welcome to the forums.
Since this is a technical issue and not a "New Member Introduction" I moved this thread to the appropriate subsection so you can hopefully get more help.
Please do not post any more technical questions in this forum.
You can use either weight, GL4 or GL5 are standards and the transfer case can work with both as well.
I ended up using Mobil 1 LS 75W-90 on my 2G MDX Transfer Case which is among the best stuff you can use in a transfer.
jujufly (04-28-2017)
I ended up using Mobil 1 LS 75W-90 https://www.amazon.com/Mobil-104361-.../dp/B000ONZXPK on my 2G MDX Transfer Case which is among the best stuff you can use in a transfer.
The first number is the cold rating The Stock stuff is 80W so by using 75W you are using a slighter thinner oil for the Summer (It only heavily affects its performance in Hot Areas, In Cold areas a thinner oil can flow the best so lower is better in the Cold)..
Using that in the summer "COULD" grant you slightly better MPG but if the oil is cheap could also make a little more Wear on the Metals (Highly Unlikely though), The second number is the hot rating which means its rated up to 90°C or 85°C of Operating Temperature...
Stock:
80W-90
You use:
75W-90 (Slightly thinner oil, Same maximum working temp)
Alternative:
75W-85 (Slightly thinner and Slightly less maximum working temperature) should improve "some" MPGs in the Summer and Winter.
They should all work all right for the Transfer Case as our transfer case does not see a huge amount of load like a 4x4.
But I still highly recommend the Mobil 1 LS 75W-90 as its the closest to stock rating and one of the best Transfer oils out there as per the Technical Tests.
Stock:
80W-90
You use:
Alternative:
jujufly (05-01-2017)
Forum Contributor
Received 1,392 Likes
See this Acura Genuine Oils and Fluids Chart
http://www.urvi.net/forumfiles/SB/Ac...plications.PDF
Per the chart, the transfer assembly uses HGO-1 (Hypoid Gear Oil, which is GL-5 75W-85).
08200-9014A (Acura branded)
08200-9014A Acura HGO-1 GL-5 75W-85 - Bernardi Parts
08200-9014 (Honda branded)
http://www.bernardiparts.com/Honda-HGO-1-Hypoid-Gear-Oil__08200-9014.aspx
Stock:
80W-90
You use:
Alternative:
Stock:
80W-90
You use:
Alternative:
Yeah it needs about .7q, there will be leftover..
The Transfer case is actually quite small that is why it doesn´t even need the full quart.
Make sure to fill it up after draining it, A member here destroyed his Transfer case because he forgot to fill it up.
jujufly (05-08-2017)
i just finish the transfer case fluid change, unfortunately, i found it is full after i pump around .6q, i don't know if this is ok. thank you very much.
2006 NBP TL MT6/ 02TL-S
Another vote for Mobile 1 Synthetic 75W-90. I've used it in all my gear cases where appropriate for years. The fact it is synthetic will more than cover the small variance in the weight from the stock 80W-90.
Be aware that the rear diff/gear case uses ONLY the Honda Rear Differential All-Wheel drive fluid
jujufly (06-20-2017)
Congrats on a Job well done!
jujufly (06-25-2017)
