Nivigation Mode Problem
Old Dec 8, 2011 | 08:25 PM
mingalar's Avatar
4th Gear
Question Nivigation Mode Problem
My MDX's navigation map does not change into night mode automatically when dark. What's wrong with that? Please tell me how to fix it. Thank you.
Old Dec 9, 2011 | 06:37 AM
db22's Avatar
Do you have a different color selected for day and night?
Do you use a dash mat? Is it covering the sensor?
What year MDX?
Old Dec 9, 2011 | 03:10 PM
mingalar's Avatar
4th Gear
What year MDX?
I didn't change any thing. I don't use dash mat or anything which will cover the sensor. I also cleaned the sensor with a micro fibre cloth.
Old Dec 9, 2011 | 03:12 PM
mingalar's Avatar
4th Gear
I forgot one thing in my reply. My MDX is 2011 Tech package.
Old Dec 9, 2011 | 04:38 PM
avs007's Avatar
The brightness on your NAV is probably set to manual mode. The easiest way to put it back to auto, is to use the voice controls.
"Setup"
"Display Auto"
Old Dec 9, 2011 | 05:16 PM
regnideir's Avatar
Bet you have the instrument lighting set to max. Go down one notch and you should be fine.
Old Dec 9, 2011 | 08:11 PM
mingalar's Avatar
4th Gear
Smile Brightness level
It works when I reduced the brightness level. Thanks,
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
rboller
Sep 23, 2015 02:49 PM
