New brake pads needed...
My baby's ride...
and I'm assuming that with new pads, the rotors need to be resurfaced? or replaced?
Anyone here had this done at an Acura dealer and how much they paid?
I have an 05 with 31k miles and 3k miles ago, I was told that I would need one within the next 5k miles by the dealer.
I had the 30k service done at Open Road Acura in NJ and I was charged $800. Most likely overpaid for that as well.
my acura dealer is pretty reasonable with it's prices, i never pay more than $420 for the maintenance's with the rear differential oil change
i got just the front done and it was around $550, that included servicing the rotors
they even resurface the rotors on the mdx and tsx for free if i ask them (before and after the breaks needed to be replaced)
i go to smithtown acura in st.james ny
Most people suggest resurfacing the rotor every other pad replacement depending on the condition of the rotor and mileage on the pads. I have never had a problem with the rotors on the X. I just changed mine and the rotor is clean. I was planning on turning them but I hardly noticed any wear so decided against it. I went to AutoZone and bought Duralast Gold Ceramics for ~$70 for fronts and rears + 1 QT of Castrol GT LMA brake fluid for ~$6. Done deal.. So whenever the dealer suggests putting in some crap pads for $250 per axle I laugh my ass off.. (btw.. the DG Ceramics have either Lifetime or 2yr Full Replacement Guarantee.. so within the replacement period just bring in old ones and get new ones free!)
If you notice your rotor has warped.. don't bother turning them. Pay the extra money for new ones. If you turn a warped rotor they will eventually warp again but much sooner than the previously noticed warpage period. I know not all are interested in doing their own brakes so here's what I suggest:
- Determine the realistic costs of doing a brake job. I paid ~$76 to do my brakes. I would have paid an extra $30 if I resurfaced / turned them. I don't advise turning the rotor unless there is noticeable wear or they have warped. I spent about 2 hours with a little help during brake fluid bleed to complete the job. A competent shop should be able to do the same. It shouldn't take no more than 45 mins to replace the pads with the wheels on. So with all that said we take a fair rate of $100 / hr + parts = $275 [new pads / brake fluid change on all 4 lines]. Any more and you probably overpaid.
- Find an independent Acura / Honda shop and do some price quotes. There are a lot of very good independent shops that specialize on Hondas [and if you think Acura is somehow different than Honda.. think again]
- Change your brake fluid and bleed all four lines. Some shops try to get away with just sucking out the old fluid in the master cylinder but that doesn't do anything! Make sure they bleed each line!
My baby's ride...
So the $1,000 approx figure my dealer was quoting me to replace pads, resurface rotors to all 4 wheels along with bleeding the lines, replacing fluids is a big time profit for them?
big time! That's why they push it and try to upsell that job. If they notice your pad life is down by say.. 1/2 which means you still have anywhere from 6k miles to 12k miles of life on them they'll try to upsell a complete brake job. My local stealership wanted to charge $120 to turn all my rotors on my TL, which was more than if I bought new rotors! Don't get me started on the cabin air / pollen filter..
Call some indie Honda / Acura shops or try searching for a DIY.
My baby's ride...
Well, the problem is I dn't know any shops other than the dealer. Never had problems where I needed to take my car in for repairs/service so often. I better see if another dealer is cheaper and try to negotiate.
lol... I have some land on Florida you may be interested in! maybe some stock in Sirius Radio.. I say it again:
Parts
Ceramic Pads - $70
Castrol GT LMA - $6
Turn rotors - $60
Labor
2 hrs - $200
I wouldn't turn the rotors if they look good.. but if you did.. it should be around $335 - $350. Why use Azine if not to learn and save some money. Everyone is entitled to spend it as they wish.. while the rest of us shake our heads when we hear BofA CEO Thain buys a $35k wooden shi*ter (ahem.. commode).
Parts
Ceramic Pads - $70
Castrol GT LMA - $6
Turn rotors - $60
Labor
2 hrs - $200
My baby's ride...
My baby's ride...
Parts
Ceramic Pads - $70
Castrol GT LMA - $6
Turn rotors - $60
Labor
2 hrs - $200
Parts
Ceramic Pads - $70
Castrol GT LMA - $6
Turn rotors - $60
Labor
2 hrs - $200
If you pay $700 then they are probably charging the time to turn the rotors as part of the labor and as a process plus taking a huge margin on parts or their labor fee is high like $150 /hr. Taking off the caliper and rotor is not complicated. The only PITA is the retention screws in the rotor.. I completely twisted several bits in my drive unit tool to remove them.. ended up drilling them out. If it wasn't for these two dumbass screws in each rotor the job to remove wheel - caliper - rotor would take no more than 20 mins at each wheel. Rub your finger on the rotor surface (only on a cold car - not after driving!) and if it feels absolutely smooth and looks good then I wouldn't bother turning them. That reduces a 20 min job to 7 min / wheel.
If I were you I'd try asking other AZ members in your area for assistance. You could save a lot of money doing the routine maintenance.. and it's real easy! If you've never changed your brake fluid on your '05 then you're due. Changing out the brake fluid takes a little patience but there are a some tips & tricks to doing it and there's even some cool aftermarket valves that make it a cinch.
so a $700 job would consist of:
Parts
Pads - $100 [dealer makes +$60]
BF - $30 [dealer makes +$25]
Turn Rotors (all 4) - $200 [all profit]
Labor
3.5 hrs @ 105 = $367.50 [include labor of removing rotors & turning them even though they are already priced - otherwise the labor price is higher like $125 for 3 hrs or 150 for 2.5 hrs]
Don't fault the dealer.. they're cheating everyone on brakes, not just you. They have standard rates for changing brake fluid and turning rotors.. They mark up parts and make huge margins on those as well. I'm not getting down on the dealer.. they have overhead (insurance, tools, disposal).. but they know that 95% of people that take their cars for service feel they are obligated to have work done at the dealership (stealership). Ask around for a good indie mechanic who works on Honda / Acura. You'll find some of the most experienced technicians running their own shops. Most techs at the dealership are young because the older ones get tired of the upsell b.s. and the shop taking more than half their pay.. the shop may charge +$100 / hr on labor but the tech only sees about ~$20-30 / hr. (getting the picture?)
08_UA7_Gr33k
02-11-2016 02:17 PM
