Low fuel Indicator
Old Feb 28, 2018 | 09:26 AM
tamamimo's Avatar
Low fuel Indicator
How can I look at how many miles I have left in my 2012 MDX after the gas light comes on?
Old Feb 28, 2018 | 09:32 AM
the 2012 MDX has a fuel tank capacity of 21 gallons.
to figure out how much fuel is left when the fuel light comes on; fill up the gas tank and subtract the amount you filled up from the total tank capacity.
I believe it's around 2 gallons left.
alternatively, I believe the MID (computer on dash) can tell you how many miles left, depending on your driving style.
Old Feb 28, 2018 | 09:51 AM
horseshoez's Avatar
Latent car nut
The Distance to Empty function on my TL is off by, oh, as much as 100 miles. Said another way, once DTE shows zero I can typically drive at least 60-70 miles of normal driving, and over 100 miles if I'm on a trip. Even with those extra miles, I still have yet to have a pump click off up in the 17 gallon range.
Old Feb 28, 2018 | 09:54 AM
yes, I believe the reserve of 2 gallons and the conservative computer display is for the absent-minded.
Old Feb 28, 2018 | 11:30 AM
mrgold35's Avatar
mrgold35
The DTE is so depended on current mpgs as calculated by the M.I.D. I would just go by the DTE shown on the M.I.D. to make sure you don't run out fuel after passing 3 gas stations. Just out of curiosity, the most fuel I put in my MDX after I drove for a while with the fuel light on was 23.7 gallons and I didn't top it off completely (I didn't see the gas in filler neck).
EE4Life
3G MDX (2014-2020)
May 2, 2025 07:39 AM
EE4Life
Nov 27, 2024 05:36 PM
csmeance
1/2G MDX (2001-2013)
63
Oct 6, 2018 05:13 PM
rets
Jan 1, 2013 09:50 PM
turbotk
Jan 2, 2002 06:25 AM
