kp tech roll up module
Old Jun 1, 2016 | 07:00 AM
sandro_am's Avatar
Hello,
anyone installed hm20 module from kptech on acura mdx 2010-2013 years?
cannot make it working. thinking that green cable from kptech is not connected correctly in my case.
if someone had installed it please share where green cable was connected?
Old Jun 1, 2016 | 08:41 AM
Did you follow this? http://www.kptechnologies.com/docs/H...stallation.pdf
Old Jun 1, 2016 | 08:51 AM
sandro_am's Avatar
sure i followed instructions, but the leg i found for green cable seems to be incorrect. (manual is for acord 04)it is very hard to find correct leg with tester, as all OEM harness should be connected to all modules to find correct voltage and pulses. all are found except green wire connection.
Si_jeff
1/2G MDX (2001-2013)
Jun 5, 2016 01:54 AM
