Help!! Transmission Electrical Issue P0962 P0980 P2720
Old 04-23-2017, 10:32 AM
dgkrishy's Avatar
Hello all,
I'm having a pretty horrible day. My 2010 MDX is throwing the codes P0962, P0980 and P2720 (3 times). All three point to solenoid circuit issues. As a result, my car is having transmission issues (hard shifting and no reverse). All else is fine with the car.
Here's a little background. Right before this happened, I removed fuse 10 (ignition solenoid) as an aftermarket video was tapping into it causing battery drain. I connected the fuse again after removing the aftermarket cable tapping into it. I didnt do anything else. I'm not sure if I accidentally shorted anything while doing this.
I'm really helpless as I need the car for work tomorrow. I ordered an OBD2 scanner same day shipping on amazon today hoping clearing the codes may help solve the problem, but I dont think it will.
I appeal for help! Thank you folks!
