Help - Identify P3025 code
Old Jan 20, 2010 | 05:17 PM
Hova1222's Avatar
Hi guys i have an o4' MDX and the engine light comes on followed by the vtm4 light. I replaced the knock sensor and tried to reset the code but it didnt work. Initially it had indicated it had a bad knock sensor. Now it gave me code P3025.
Does any one know what that means? can it be an O2 sensor i am getting horrible gas mileage, close to 13 mpg combined.
Any help would gladly appreaciated.
Old Jan 20, 2010 | 05:40 PM
FiftyFive's Avatar
Moderator Alumnus
Usually its pretty simple to look up codes online but I am having a hard time finding one. You sure its p3025?
Old Jan 20, 2010 | 08:14 PM
Hova1222's Avatar
sorry its Code : P0325
it also said low fuel pressure
probably the fuel pump? this is prob why im getting low mpg?
Old Jan 21, 2010 | 12:12 AM
240sx acura tech's Avatar
acura master tech
well you check that sub harness. they get eaten by rats. and ive never seen a fuel pump go bad.
Old Jan 21, 2010 | 12:15 AM
FiftyFive's Avatar
Moderator Alumnus
Here ya go:
http://www.obd-codes.com/p0325
If it's not the sensor, because you've already replaced it, maybe the harness or wiring to it?
And what do you mean by "it also said". Did it read another code as well?
Old Jan 24, 2010 | 09:29 PM
csmeance's Avatar
check the wiring to the sensor and look for some rat droppings in the engine bay. Acura used some soy based coating on the 2004+2005 cars and rodents like to chew on them.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
