Help - Identify P3025 code
Hi guys i have an o4' MDX and the engine light comes on followed by the vtm4 light. I replaced the knock sensor and tried to reset the code but it didnt work. Initially it had indicated it had a bad knock sensor. Now it gave me code P3025.
Does any one know what that means? can it be an O2 sensor i am getting horrible gas mileage, close to 13 mpg combined.
Any help would gladly appreaciated.
Moderator Alumnus
Here ya go:
http://www.obd-codes.com/p0325
If it's not the sensor, because you've already replaced it, maybe the harness or wiring to it?
And what do you mean by "it also said". Did it read another code as well?
check the wiring to the sensor and look for some rat droppings in the engine bay. Acura used some soy based coating on the 2004+2005 cars and rodents like to chew on them.
Jamus22
06-11-2023 10:08 AM
