Got my wheels today. 20" Stance SF01
mrgold35
I like the look!
Did you keep the old tires/rims and used one as a full size spare. I wasn't too comfortable with the OEM wheel locks and went aftermarket with Gorilla 61641 Acorn Guard Locks (14mm x 1.50, Amazon, $16). Since I kept my OEM rim as a spare, I had to keep a set of Spherical (round or ball shape) OEM lugs in the MDX because they are different from my Conical (cone shape) RonJon rims lugs.
Yes I kept my OEM wheels/tires and lugs. On a different note, my MDX has been pulling to the right since I puchased it. I got it used though. I got brand new tires with the wheels and the shop did an alignment too. Still pulling to the right. Any idea what could it be?
Remind me of the vossen cv3 wheels.
Mr. Merky (11-08-2015)
mrgold35
I would test out some different areas with old, regular, brand new pavement to see if the problem is just with the hwy department. Then I would adjust PSI to see if that might change/improve the dynamics. You can pretty much feel the road conditions in the steering wheel, pedals, your backside, and ears when driving. That is one of the things I like about Acura vehicles driving dynamics (not isolated; but, the most important part of the vehicle).
I'll just upgrade to some Powerstop cross drilled/slotted rotors and pads and project is done.
Since you already did the alignment, tire pressure, and balance; not much left to check other than suspension and/or steering? I have to put in an extra 3-4 PSI to get the feel I like with my set-up (MDX doesn't feel right at 32 psi with the soft sidewall Conti DWS). Every time I put new tires (Conti DWS last +5yrs); they really follow the rain groove marks in the same direction of travel on the concrete section on the hwy. The grooves kinda wander a bit and pull the vehicle to one side or the other with the new tread. The problem goes away after the tires break in after around a thousand miles. We also have a lot of semi-trucks on the roads and truck grooves on asphalt also pulls my vehicle to one side sometimes along with the natural crown of the hwy for drainage.
The first time I saw the Vossen CV3's I knew right away that was the look I'll be going for. I just couldn't justify spending that much on those wheels. The local shop I went gave a me good deal on the SF01's. Under $2k OTD for the wheels, tires, hardware and alignment.
Keep is updated!
Mr.Tea (03-27-2016)
mrgold35
Since I got my tires at Discount Tires, I do the lifetime rotation and balance to save a little $$$ at the dealership. The Discount tires near my house can do road force balance for free since I got the tires with them. I would do a road force balance with aftermarket rims at least once or if you put new/different tires on with aftermarket rims (summer/winter swap or just replacing worn tires).
mrgold35
Since I travel a lot, I am extremely paranoid about finding my MDX on bricks at an hotel +1000 miles out of town. I added a front/rear dash cam and two sets of wheel locks to my MDX. Anything to slow them down, I know I really can't stop a determined thief.
I also got a torque wrench and always re-torque to 94 lb-ft after any tire work at a shop. I had to get a 2ft breaker bar because Discount Tire usually over torque the lugs waaaay past 94 lb-ft 99% of the time. They once broke a stud on my TSX because they had the impact wrench turned up so high.
Mr. Merky (11-11-2015)
telele
03-20-2016 06:33 PM
tgt
10-09-2005 09:24 AM
