Front suspension help!
I had my front non Electronic leveling struts replaced with KYB Gas replacements. Rides great but the right front spring is rubbing the body. Mechanic tells me the strut must be bent or the spindle is bent. 1 owner car, so I doubt that. Anyone come across this problem??[
Was there a rubbing issue, before you had them replaced?
It sounds like you re-used the spring and replaced the shock.
There is a mark on the top plate of the assembly housing that needs to point to the front of the car, hopefully it was installed correctly.
