Front and Rear Brake replacement help
Old 01-01-2016, 05:14 PM
3rd Gear
SamC2016's Avatar
I have a 2011 Acura MDX with Tech Package and I am going to be doing the front and rear brakes and can't find the torque specs for the front caliper bolts and the rear caliper bolts, etc.
I did see lots of posts about the rotors and pads to use and have already ordered the parts just need the specs now.
I don't want to use the wrong numbers and have seen where the wheel lug bolts in older models was 80lbs and for the newer models is 94lbs. I want to be sure i have the right numbers and can't find the exploded view diagram for the brake systems.
Sam
Old 01-01-2016, 07:17 PM
Carpayment4life's Avatar
In the 07-09 service manual:
pg 19-18 front caliper body bolts = 53 lbf-ft
pg 19-29 rear caliper body bolts = 27 lbf-ft
Old 01-01-2016, 08:35 PM
3rd Gear
SamC2016's Avatar
Can you verify these are still the same for 2011?
Old 01-01-2016, 09:02 PM
dzionny_dzionassi's Avatar
it is just brake caliber, i Never saw anyone checking torque spec brake caliper.
You will fine with provided numbers....
Old 01-01-2016, 10:03 PM
Besides, getting a torque wrench in behind the caliper might be a tight squeeze.
Before you try to push the caliper piston in, you should open the brake fluid reservoir lid. Wrap a rag around the reservoir, in case it over flows.
Old 01-02-2016, 11:55 AM
3rd Gear
SamC2016's Avatar
thanks for your feedback, I will be doing the brakes today!
DwDrummer
05-19-2018 06:35 PM
Addicted2Racing
02-09-2016 01:56 PM
MikeRadio
5G TLX Problems & Fixes
01-23-2016 09:49 PM
vhdoshi
01-10-2016 12:26 PM
Con_JohnneryTSX
12-28-2015 09:41 AM
Quick Reply: Front and Rear Brake replacement help
