Front Clunking Noise
Old May 27, 2016 | 06:26 PM
korrupt3dazn's Avatar
Hi All,
So Im having this front Clunking noise when going over bumps or even starting the car sometimes. I took it to Acura to Diag it and they said it was front struts.So I replaced the both front sway bar bushing, both end link, both front struts and and both rear shocks...... still the same noise is there. I don't know what else to check.....
Old May 27, 2016 | 07:16 PM
Skirmich's Avatar
When I was looking for the same answer for my clunk somebody pointed out the A-Arm Bushing. It has a TSB for it about clunk noises when you accelerate or brake.
Old May 27, 2016 | 10:46 PM
acurapartsdiscount's Avatar
Former Sponsor
Check the compliance bushings(big bushings on lower control arms). Also check the motor mounts
Old Jun 1, 2016 | 04:42 PM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
Anyone figured this out or fixed this yet?
Mine has it pretty bad. Checked all the rubber I could see, lower control arm rear bushing, the big suspension isolation bushings front & rear, sway bar end links & bushings, didn't see any problem.
I'm wondering if it the struts, it sure doesn't ride & handle like bad struts/shocks, but I am not familiar with vehicle previously to compare. The dealer I bought it from said the struts had been replaced (lately), but they look like they have been in there awhile
Old Jun 1, 2016 | 10:34 PM
csmeance's Avatar
the issue is with the spring and the top hats for the shocks
Old Jun 2, 2016 | 01:12 AM
AlanW's Avatar
What's the solution, new top hats, or the big rubber gasket spring seat?
And is it front only or could be rear ones also? Mine sounds like a coffee can full of rocks, I can't tell where it's coming from.
ericinbrooklyn
4G TL Problems & Fixes
20
Dec 14, 2024 04:29 PM
00TL-P3.2
Feb 11, 2019 11:23 AM
2004TL_
Apr 29, 2016 11:40 AM
Udry215
Apr 11, 2016 05:01 AM
NerdO_TL
Feb 1, 2016 05:58 AM
