Flashing CEL
Old Oct 4, 2008 | 09:17 PM
formula1's Avatar
Flashing CEL
Drive a 2004 Acura MDX and recently put a UR pulley on and also removed the intake resonator i also have a drop in K&N drop in filter. Question i have is when i accelerate hard (VTEC area) i get a flashing CEL and it does not go of until i let of the gas a bit and press the gas again. I dont know if it's the Pulley or the resonator. Anybody run in to this before?. Any info on this would be great. Thanks,F1
Old Oct 4, 2008 | 09:49 PM
csmeance's Avatar
the pulley is causing it, the TL has this issue to. Flashing CEL means misfire...
Old Oct 5, 2008 | 02:06 AM
formula1's Avatar
Anything you can do about it or removing the pulley would be the only thing that would fix the flashing?.
Old Oct 5, 2008 | 02:05 PM
csmeance's Avatar
it should go away by itself after a while. thats what happened to the TL guys. The first few times it would give a CEL, then it would not come on...
Old Oct 6, 2008 | 10:03 AM
formula1's Avatar
Flashing CEL
I reset the ECU and that seemed to take care of it. Just so everybody knows.
Old Jan 13, 2009 | 05:56 PM
meburdick's Avatar
'17 RDX Tech AWD - WDP
FYI - A flashing CEL typically (at least, used to) mean TURN OFF THE ENGINE NOW whereas a lit CEL meant "you should have it checked".
Old Jan 14, 2009 | 01:36 PM
007Acura's Avatar
post a video of those mods working
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
samson_420
Oct 8, 2015 01:47 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
ceb
ILX
Sep 27, 2015 10:56 AM
